Question about Dynex 19 in. LCD Flat-Panel HDTV
Dynex (no database) since power outage
While I was flipping channel on tv and had a power outage then tv saying No Database.. My other tv works and so what the heck does that mean?
  • 3 more comments
  • tdeepwood Oct 03, 2008
    I mean what does the heck mean no database??? I could not get the tv to work again.... I have another tv in other room works fine....
  • tdeepwood Oct 25, 2008
    Thanks GOD!!! My Dynex TV is finally once again back to LIFE!!! It have been out of order for about a month... BIG CHEERS!!!!
    Many Thanks and You ROCK!!!!!
  • ebonique1 Feb 26, 2009
    I have the same problem with a dynex dx-ltdvd20. I have had it unplugged for about a day and a half, so now i will unplug the cable as well. I hope this solves the issue its only 14mnths old. I'll try to turn on tomorrow or the day after and let you know
  • Anonymous May 09, 2009
    Our Dynex 19" with DVD Integrated just went caputz. I turn it on and it either gives me the no database issue or it just blinks on and the screen goes black. My 360 is connected to it and It blinks the picture once then goes black. I dont have cable I only use it to watch movies or play in my xbox360...
  • Anonymous May 17, 2009
    dynex dx-ltdvd20. 13 mo. old, same problem. TV blinks once, then a black screen. At first it would take me 3 on and off tries, then it worked. Now, nothing.
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Posted on Jan 11, 2009
I solved the no database problem by unplugging it overnight and doing an auto scan on the free channels then doing an auto-scan on with the cable connected.......i did follw the solution above but this did work for me.
Posted on Jan 24, 2012
Nothing works except the on and of button, manually or remote. (dynex dx-lcd 19''
Posted on Nov 09, 2008
Sloved!!! All you have to do is unplug the power and the cable connection for a day... It will reset the database.. Then put power back on to the TV and turn on the tv on one channel without cable.. Then set the tv to air instead of Tvcable... The database should reset itself and then change the tv mode back to TV cable...The TV is working fine..
Posted on Oct 24, 2008
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
Vivitar tv shows small square box that reads auto scan required. What does that mean?
YOU MOST LIKELY HAVE TO REPROGRAM THE CHANNELS THAT YOU GET.THAT IS WHAT THE AUTO SCAN DOES IT RESETS CHANNELS THAT RE NOT SCRAMBELD
Aug 09, 2012 | LG Televison & Video
No pic please run channel auto scan
It means it is not detecting signal etc.
If you had a power outage unplug the set for a short period of time and plug it back----if using a box for signal do the same.
This may allow set or box to reboot and function again.
Also you can try to hook a DVD etc to a rear audio/video input to see if that works.
Mar 31, 2012 | Televison & Video
My tv is now saying "no signal" i was out of otwn for a few weeks and this is what had happened while I was gone. The dish network says it is not their issue that we are unable to get to cable...
If the TV needs to be on channel 73 [TV tuner] for the dish to work then do a channel serch in the tv's menu.
If you had a power outage when you were gone the TV will need this scan done.
Most sattelites use the inputs not the tuner. make sure your on the right input channel,
Jul 22, 2011 | RCA Televison & Video
What does "freeview database empty"
My tv has been working fine and all of a sudden it wont find any channels on channel search and says "database empty" can anyone help??
Mar 08, 2011 | Televison & Video
How to get TV audio on the FR300 radio?
Your TV band radio won't work anymore now that the US has switched to digital broadcasting. The frequencies now in use aren't the same now, so the radio can't receive them. Plus, the radio doesn't have the circuitry to decode the digital sound even if it could pick up the broadcasts.
Sad to say, you have a radio that now picks up only AM/FM/weather and static. Also, as far as I know, nobody is yet marketing a radio for TV sound with digital capability. All you can do during a power outage is use a new TV with battery capability and digital tuning.
Mar 02, 2010 | Eton FR300 AM/FM/Weather/TV Radio
My flat screen lg tv has lost its channels,says its not programed...help
i was watching tv last night on my lg,and it went off and said no signal?so i went to retune and now it says not programmed i cant get my dtv channels back
Aug 20, 2009 | LG 42PG20 42 in. Plasma HDTV
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Memorex LCD TV Say "NO DATABASE"
sayno lcd is on but the screen is very dark
Mar 13, 2008 | Memorex MVD2019 19 in. TV/DVD Combo
Dynex 19 in. LCD Flat-Panel HDTV Logo
2,141 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
