Question about Zanussi ZJD1219 Front Load Washer / Dryer
Fills with water then stops
My Zanussi ZJD 12191 when on any wash program will fill with a bit of water as normal, spin one way then the other as normal the puts more water in as normal but then stops, The timer goes back to the total wash time and the start pause button light flashes and does no more.
  • Anonymous Jan 17, 2009
    I have the same machine and the exact same problem, starts normally allows water in, drum turns then allows more water in then stops and returns to original time of programme. Please help
  • 1462 Answers
SOURCE: the Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Posted on Mar 27, 2007
Oceti
  • 51 Answers
SOURCE: Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Posted on Dec 13, 2007
  • 106 Answers
SOURCE: zanussi jetsystemiz12 start /pause button flashing wont start
www.enet.electrolux.com-TroubleshootingHomepage
Posted on Feb 28, 2009
beltronic205
  • 1474 Answers
SOURCE: unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Posted on Oct 02, 2009
Testimonial: "this is very helpful, Allthough I am not capable of carrying out this work I do at least know what the repair guy may say. thanks."
SOURCE: hi my zanussi zwf1432s stopped halfway through
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Posted on May 05, 2010
Zanussi jetsystem ZJD-12191 TURBODRY washer dryer drum will not turn
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 22, 2013 | Washing Machines
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Power button seems to be broken
the trigger has been damage you have to replace it .if you want i can fix it im a technician
Jul 18, 2009 | Washing Machines
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZJD1219 Front Load Washer / Dryer Logo
56 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
