Question about Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each
Pride Legend surges at any speed & makes a clicking noise
My Pride Legend surges at any speed & makes a clicking noise
  • 2 more comments
  • CaptElad Nov 30, 2008
    Thanks dhudson15, I will look into purchasing a throttle Pot, do you feel it's the small one on the tiller connected directly to the Throttle or the Larger one further into the Machine?
  • CaptElad Dec 01, 2008
    Thanks dhudson15, I have now looked into the prices of the two pots and the larger one is very steep, so befor I purchase either I will dig out my VTVM as you suggest, looking for smooth response!!
    Again thank you, and do you have any suggestions as to the clicking noise coming from the Motor/Axle, it varies with my speed!!
    Thanks for any help you can give me on the clicking as well!
  • Anonymous Mar 15, 2014
    Pride legend tiller adjustment lever broke how to fix it
    Lever broke
  • 118 Answers
This sounds like a bad throttle pot. You need to have it replaced.
Posted on Nov 27, 2008
  • 2 more comments
  • Dan Hudson Nov 30, 2008
    I can get a replacement for you if your going to try replacing it yourself, or are you looking for a local repair shop? Looking at pridemobility.com has a list, and there are more that are not on their website but they will give you over the phone.
  • Dan Hudson Dec 01, 2008
    There are two pots, one for speed only, and one for speed and direction. It is the speed/direction pot that I have seen go bad. It's basically a 5k long stem pot with a centering spring. Its available from Pride only as an assembly. I would test it to be sure, you should see aa smoth response across the entire range on motion. The only other issue is bad wiring, which I saw after the owner tried to play with it and hooked it back up wrong.
    Yes, depending on model, that assy lists for up to about $200. I try to be very sure at that price. If you want specifics, you can emial you s/n to me at d h u d s o n 1 5 at g m a i l with a .com extension (take out the spaces) and I can talk more specifically to your model.
  • Dan Hudson Jan 04, 2009
    I suspect that the pot is dropping out and the clicking is the brake turning on and off as the pot calls for brake and then speed. EMail me at D*H*u*d*s*o*n at gmail dot com (take out the stars and fix the gmail for my address) and I can better their price for ya. I may even have an old pot you could use to rebuild yours...
Pride ultra making noises during ride
If you turn to the right and the speed of the clicking sound goes faster then your left wheel has the problem. The shaft key is a little loose and is shifting while running. If you turn to the right and the speed of the clicking sound goes slower then the right wheel has the problem. Sometimes a stick will become lodged underneath making contact with the wheel or rim making a clicking noise. These noises can drive me nuts. Scooter Doctor App
Jun 01, 2016 | Pride Health & Beauty
Pride legend suddenly stops and emits 7 beeps
hi , that is a throttle pot error, check the pot itself to make sure it's not come loose and check the connected wiring ...
Regards
Rob
www.gewizrepairs.co.uk
Jun 21, 2014 | Pride New Mobility Legend 4 Wheel Scooter
I have a 3wh. 'LR'model Pride scooter for
I'd be looking at the motor controller first. Since you don't have any flashing leds to indicate a problem, perhaps the brushes on the motors need replacing.
Jul 28, 2017 | Pride Mobility Products Pride Mobility...
The kids drove my Pride Legend XL through a puddle. I doesn't go anymore. I need a technical Reference Manual with schematics. I could fix it myself or......? Batteries are fully charged. No...
I had a similar problem with my Pride Legend XL when I drove it
through a puddle accidently and some water splashed up underneath
the motor controller. It would buck or go then stoo without any warning
as the electric brake was applied. Had to take the seat off and use a
hair dryer on the controller connections to dry them out. It doesn't
seem to take much water to make these inoperative. After thoroughly
dried out with a hair dryer..no more problems like that with it.
Oct 27, 2011 | Pride Mobility Products Pride Legend XL -...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Oct 19, 2009 | Pride Mobility Products Pride Legend XL -...
Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Sep 23, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Apr 24, 2009 | Drive Medical Mini Phantom Three Wheel...
Performance/Range issue with Pride Legend Classic
If only one wheel turns then it sounds like the transaxle is bad. They are a sealed unit and cost around $1000.
Jan 20, 2009 | Pride Legend 3 Wheel Mid-Size Scooter
Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each Logo
607 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
