Question about Sewing Machines
Bernina 1300 dc overlocker does not form stitches on chainstitch
My overlocker doesnt make chainstitch without loops on the underside, i recently tried removing the oval discs on the inside where the thread is passed around as there was a lot of thread wound around the moving base, so i lost the correct positioning of the discs, can anyone tell me how to get the right positioning as i believe this is the problem. i live on a tiny island that hasnt even heard of bernina so i have to perform all repairs myself any information will be really appreciated.
4 Suggested Answers
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
micromaster
  • 3614 Answers
SOURCE: Starting overlocking
hi there,
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Posted on Jun 01, 2009
SOURCE: got bernina 1015 sport sewing
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Posted on Jul 24, 2011
Testimonial: "very helpful thanks"
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
How do I make a new buttonhole on my 1260? B
Hi Karen,
Sew two parallel lines of overlock stitches very close together. Then see overlock stitches accros the ends of the first lot of stitches to close them off. Finally, carefully cut the fabric between the first set of stitches. Try this out several times on some scrap fabric. You'll need to get the spacings sorted out.
Jul 19, 2015 | Sewing Machines
The upper looper on my Bernette 334Ds overlocker will not move backwoods and forward hence no loops or stitches being made. How do I fix this?
Has it been professionally cleaned and oiled recently? Even though the manuals usually don't provide instructions for oiling the inside of a serger, they do need it periodically because of all the moving parts. If you don't feel comfortable doing it yourself, then maybe a trip to the Bernina technician is in order. (Please if you try it yourself, be sure you have the proper oil, preferably Bernina serger oil--not Bernina sewing machine oil.)
Mar 28, 2015 | Sewing Machines
Overlocker looping(forming chain stitch) not stitching on fabric
try new needles
make sure tension is correct
could possibly be in need of some adjustment
Mar 29, 2014 | Sewing Machines
What should I pay for a Bernina 1300dc. It has been used once and stored in a box for years. All parts, manual are included.
Take a look on amazon for Bernina sewing machines... You can find there various prices (100% cheapest on the net). Here: . Amazon com bernina sewing machines. I hope this was helpful. Cheers
Sep 21, 2011 | Sewing Machines
hi there,
  • Replace needle.
  • Reset needle.
Jun 01, 2009 | Bernina Sewing Machines
Stitching too tight on top
I found a screw on the bobbin case (where you put the cotton for the underside stitching) which was very loose. I tightened it and that created more tension for the bottom thread which solved the problem.
Jan 02, 2009 | Bernina Activa 130
Bernina 1300 dc overlocker skipping stitches
Rob
Mar 14, 2008 | Sewing Machines
Sewing Machines Logo
85 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
