Question about Mitsubishi VS-45607 45" Rear Projection Television
Can't find any one to fix my tv
My tv shuts off on a regular basis. it may do it after a few hours of use or ten minutes. it might turn back on after a few minutes or an hour. i hear a click when trying to turn back on. can this be caused by the equipment hooked up to it? i called around to have someone come look at it and no one works on mitsubishi tvs
  • Mitsubishi Master
  • 8,617 Answers
The following link may be able to help you diagnose your problem, they are mitsubishi experts.
Just leave them a email with your model number and what its doing.
Posted on Oct 03, 2008
LCD TV backlight goes off but still sound is present. Sometime it happen within few minutes and sometime take 30 minutes plus. Is that inverter Problem or CCFL? how I can rectify?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 12, 2016 | Philips Televison & Video
My video screen turns off after about an hour but sounds works fine.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
LCD TV Repair Tutorial Backlight Inverter Common Symptoms Solutions How to...
Nov 12, 2015 | Televison & Video
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
32" phillips tv turn self
If you go to this website,
You will see firmware information on the right hand side of the screen. Please open and read the Firmware Upgrade Read Me file. These contain instructions and the update history of this model TV. Underneath the Read me file you will find the download link. You must follow the instructions in the read me file or you risk damaging your unit further.
This is from the read me:
The set is switched OFF/shut down by itself after a few hours turning ON.
The newest upgrade should fix all your issues.
Hope that helps!
Jul 19, 2011 | Philips 32PFL5332D 32 in. LCD Television
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Jan 03, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Mitsubishi VS-45607
there is a protection circut that will shut down the tv when it detects a failure in one of the components , when components heat up to much they go into thermal breakdown, the part that is heating up and failing is getting worse , so it will need to be test to determine which one
Oct 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Go to for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Mitsubishi VS-45607 45" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
