Question about Samsung Washing Machines
I have a samsung wf306law/xaa front load washer that wont drain and now the pump just hums.
SOURCE: Samsung Washer WF306LAW stopped draining and won;t spin
Drained the water from the tub into a bucket. Since the water flowed through the disharge tub I knew there were no obstructions in the line. I then took took the discharge pump out and took it apart. Turned out to be a bobby pin in the motor that was jamming the impeller.
Put it all back together and it works just fine. Took me about 2 1/2 hours total to diagnose and repair.
Posted on Aug 31, 2008
  • 56 Answers
SOURCE: WASHER WONT DRAIN
Take off the lower panel ( 2 screws on bottom) pullout and down to remove. Make sure unit is unplugged pump is on the right hand side one hose coming from bottom of tub and the other goes out the back to the drain. Take off the hose from the bottom of the tub and be ready to catch alll the water in the tub suggest you use shop vac and remove all water first. look in the impellar in pump should be a clog right there then put everything back the way you toook it off and be careful to get the hose back on the way you took it off there is a slot in the hose and a tab on the pump for alignment.
Posted on May 30, 2009
SOURCE: I have a WF306LAW/XAA washer
I have the same problem and was told that a coin had blocked the pipe going to the pump. have a feeling he was not being honest as its happening again and have ckd the pipes going to and from the pump and i see nothing blocking either one. its noe leaks from the detergent despenser and the mold on the front is getting worse even though ive used bleach, left the the door open when not in use and left the despenser open. I give in!!!!
Posted on Jun 02, 2010
SOURCE: Samsung Front Loader wf306law took off back panel
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
Posted on Jun 21, 2010
SOURCE: I HAVE A SAMSUNG WASHER MODEL WF306LAW/XAA IT HAS
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
Samsung washer ND code and not drain and spin
Sounds like control Board isn't sending voltage to pump. Most likely a control issue.
Nov 03, 2017 | Samsung Washing Machines
Washer won't drain
ND means No Drain(ing). First check that the drain hose isn't kinked. Then, check to make sure the drain hose isn't pushed so far down into the standpipe that it is sealed closed. If it is too tight in the standpipe, it will create a siphoning effect. It has to sit freely but securely in the pipe.
May 30, 2012 | Samsung WF337AA Front Load Washer
MY WF218ANB/XAA WON'T DRAIN BETWEEN WASH AND SPIN CYCLE, AND GIVES ME AND ND CODE
Hi gumby323,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 09, 2011 | Samsung WF218AN Front Load Washer
My Samsung WF218ANW/XAA front load washer will not drain & the display reads "nd". I have already drained the water through the front panel tube & have cleaned that filter, washer still...
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Jan 22, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Samsung Front Loader wf306law took off back panel as we had lots of water under neath ran washer rinse/spin soon as the cold water came in there was water all over the inside any idea why? the washer is...
Jun 11, 2010 | Samsung WF337AA Front Load Washer
Aug 30, 2008 | Washing Machines
Washing Machines Logo
381 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
