Question about Samsung HL-P6163W 61" TV
Bad Color after replacing Color Wheel, removing jumper wire did not fix it
Replaced the Color Wheel solely because of its noise, the color & picture were fine before. Tried the suggestion of removing the jumper wire (I suppose it was the proper one--it's really short) but then the tv would not come on at all, indicating "Lamp, Stand-by, Temp." Put the jumper wire back, tv came on but color was still awful. I've invested so much time and energy, plus the price of the color wheel, that I hate to call in a repairman! Thanx, Salee
  • saleedavis Oct 05, 2008
    I'm thinking the wiring on the new color wheel is wrong, because I pulled the tv apart again, took out the new color wheel and put the old one back in. When I had the old wheel out, I dropped a few minute drops of WD-40 on its axle, spun it around a few times, and dropped a bit more onto it. It seems the blue wire (the group of two white and one blue) attaches opposite than the original but there's only one way it will connect. I re-assembled the tv with the old wheel, and the color is good; the buzzing noise subsided after about 30 seconds on the first powerup, but has since returned. It might diminish somewhat after the tv has been on for awhile, but I've still got to figure out if the wiring on the new wheel is opposite (Suppose I should contact the parts supplier!) Anyone have any suggestions on how to reverse the wiring?
  • kayrouzj Nov 04, 2008
    just replaced color wheel, red blue colors reversed. blue faves. need help, thank's.
After removing jumer, all is perfect.
jumper is inside an opening abut 3/4 inch under label, remove what looks lie rubber.
Posted on Nov 21, 2008
  • kayrouzj Nov 25, 2008
    i wasted 3 color wheels before i solved the problem. after replacing color wheel and before turning tv on you must remove the jumper , this will restore proper colors more vivid than new. jumper is inside opening inside a vertical metal plate about 1 inch under sticker.it is black rubber remove it and reverse color problems will be resolved. if you dont remove it you will destroy the color wheel.
My Samsung DLP 5663W was making the loud humming noise. Picture was just fine, but the noise was loud. I checked both fans which seemed to be fine, so I ordered the replacement color wheel. When I replaced...
On the metal box where the two cables from the color wheel plugged look for a tiny rectangular opening in the metal shield---there is a tiny jumper plug there, remove it carefully with a tiny pair of needle nose pliers.
One of the things they do not tell you when you replace the color wheel, it is somewhat different than the original one.
SD TECH
May 06, 2011 | Samsung DLP HL-P5663W 56" TV
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Color Wheel
Here's a good article on the Color Wheel
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Color wheel
could be a jumper on the DMD board that must be removed, look for a small sticker that points to the jumper, or it could be a setting in the factory mode, mute-182-power will get you in there, check the settings for the color wheel
Jul 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel replacement
With the back off of the unit, you are looking at a silver can on the light engine. The is the board where the DLP IC is located. There is a large heat sink right in the middle. Near that heat sink you will find a small square cut out where two pins protrude from the inner bd. There is a small black piece across those two pins, that is the jumper. With a needle nose slide that black jumper off of the two pins. Normally if the color wheel is changed and the jumper not remove the picture is very poor with ugly green and purple negative look.
Jun 15, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
SAMSUNG HL-P4663W 46" DLP COLOR WHEEL PROBLEM
Hi...No need for a different jumper or different color wheel. It's an easy fix. Make sure your TV is turned off and remove the jumper with a pair of needle nose pliers. Just keep it in case you may need it in the future. I will post a picture to show you where the jumper is located.
Apr 09, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP4663W color wheel replacement
When I removed the jumper wire the screen color problems I experienced after changing the color wheel were fixed completely. I did not need to reset the CCA values (which came with my color wheel, on a separate sticker). If you have a black bracket blocking access to the jumper wire, as I did, you can access the jumper wire by removing the fan shown just to the left of the yellow and white sticker; there are two screws attaching the fan to the chassis below it. Next, remove the two screws that hold the silver clamshell (the housing for the circuit board) halves together. These screws are right behind where the fan just was, on either side of the protruding fins. They each have a spring under the screw head. You can then pull the visible half of the silver housing forward (with the bracket attached). You will then have access to the entire circuit board. Look for CN810 - it is located right behind where that bracket just was when it was all put together. Pull the tiny black plastic part (that has the jumper wire) off of the pins. Then reassemble the housing and put the fan back on.
Jan 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-P6163W 61" TV Logo
1,174 people viewed this question
Jerry Greenberg
Jerry Greenberg
