Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2001 ultra classic motor miss
This ultra classic has a motor miss at 1500-2000 rpm,It is more noticeable sometimes than others. I bought this motorcyle in July, it has been doing this since i purchased it. Harley has replaced the crank sensor this did not fix the problem. Recently the bike quit and i returned it to Harley they said the ground battery post was melted so they replaced the battery road it and told me it was ready. I still have the miss.
  • 216 Answers
Electrical problems and **** in the gas tank can cause misfires. It sounds more electrical in your case. But draining and flushing the gas tank is a cheap fix. Could also be a coil or spark plug problem. Check for a faulty, fouled or cracked plug, check for a good spark, check the coil for carbon tracking. Check the plug wire connections too and the wires.
Posted on Oct 04, 2008
2001 ultra classic engine revs up and down and miss out while under load
Sound like the carb is fowled, add some fuel stabilizer to gas like - STA-BIL (find at any autoparts store). Add according to directions, this will help break down any deposits and waxes that form in the ports (& jets) of carb. allow a good hour ride to notice a difference. Then store bike with fresh gas and STA-BIL. Works most everytime. Prost! Ps: Much cheaper than rebuilding carbs too!.
Nov 11, 2014 | Motorcycles
RPM's a little high in 5th gear on a 2001 Harley Davidson Ultra Classic
Do you made any change on rear sprocket or front drive sprocket recently?
Apr 11, 2014 | Harley Davidson FLHTCUI Electra Glide...
Can u install newer model gauges in a 2000 electra
Hi Clifton, 4 out of 5 Harley Gods give this one a thumbs up, but just to be on the safe side contact your local dealers parts department for confirmation. Good luck
Aug 31, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
2001 ULTRA CLASSIC HARLEY FLHTCUI LOCATION OF OIL DRAIN PLUG
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
picture of 2004 flht drain plugs Google Search
Jul 27, 2012 | 2001 Harley Davidson FLHTCUI Electra Glide...
I have a 2001 Ultra Classic. When i go to start it it wants to backfire really bad and when it does start the rpm gauge wont work, but sometimes you can turn the switch off and back on and start it an
Hi Parker1973, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Mar 11, 2012 | 2001 Harley Davidson FLHTCUI Electra Glide...
2001 ultra classic tire size
Specifications: Engine Type: 1449 cc, 4-Stroke, Air Cooled, V-Twin
Engine Bore and Stroke: 95.3 mm x 101.6 mm
Valves 2 valves/cylinder
Claimed Horsepower: 67 hp (50 kW) @ 5200 rpm
Maximum Torque: 110 Nm (81.1 ft. lbs) @ 3100 rpm
Transmission type: 5 speed
Final Drive: Belt
Tire - Front: 130/90-16
Tire - Rear: 130/90-16
Brakes - Front: dual 292 mm discs with 4-piston calipers
Brakes - Rear: single 292 mm disc with 4-piston calipers
Sizes can vary depending on what has been done to the bike.
Ride safe and loud pipes save lives.
Dec 14, 2010 | 2001 Harley Davidson FLHTCUI Electra Glide...
Want to know where the elelctrical alternator is located on a 2001 ultra classic.
on the left side of motor,behind the drive sprocket.primary drive system must be removed to access it.eliminate fault at all other components first.mine has been in service for34 yrs.
Sep 23, 2009 | 2001 Harley Davidson FLHTCUI Electra Glide...
Could you tell me where i can find a ultra classic raido manual for 2001 bought did not have one
type it into an E-Bay motors search or contact your motorcycle dealer to see if he can order one 4 ya !....Good Luck to you friend....Tim
May 12, 2009 | 2001 Harley Davidson FLHTCUI Electra Glide...
Lands Phones Logo
200 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
