Question about Premier Heating & Cooling
I made a big boo boo
My window a/c unit was freezing up, while evaluating (which i now know was it needed tilting) I realized it needed a serious cleaning. well while in the process of putting it back together, a wrong screw was put in the wrong place and I have pierced one of the copper coils on the side of the aluminum coil. I have $0 to purchase a new unit and I live in the very hot state of arizona. i now have freon leaking and im frustrated! what can i do?
  • 1,543 Answers
FYI . This is not a do it yourself repair (brazing line, adding charging valve and new filter drier, evacuating system, charging system with new refrigerant) and the repair would most likely cost more than a new window air conditioner. Please don't bother rating this.
Posted on Oct 03, 2008
My LG Air Conditioner started having problems this weekend. It is ony 3 years old and it keeps freezing and blowing out hot air
Since you don't give a model number, I will have to assume that it is a window unit, if not this probably won't apply. When a unit freezes up - as in ice on the evaporator fins it is usually either a low freon condition or the fan is not moving air accross the unit.
With the supper high temps that we are experiencing, many units that are undersized for the area that it is trying to cool are having serious problems. One client called us out to respond to a similar problem, so we charged the unit to factory specs. A few days later she called and said that the unit wasn't cooling properly, so we went back out. Since it was a window unit that was in the bedroom, it was a small unit. She was leaving her bedroom door open with fans to draw the cold air out to the rest of the house, which the unit was not sized to do.
Jul 25, 2011 | LG Heating & Cooling
I have a window air conditioner and it has been doing good for 2 months. Now lately drops of water are flying out of the air vents, what gives?
This tells me you have possibly 2 problems..
1. you need the unit to tilt to the back (outside) to prevent the condensate from coming inside.
2. the unit might be iced up. meaning it is not cycling off -often enough. this is a window unit so you might be trying to cool to big a space with it on real humid days. i would advice you close off unused rooms as well.. But my money is on 1.
Jul 15, 2011 | Haier Heating & Cooling
Uninstall deep freeze, forgot password
If you are licensed for Deep Freeze Standard and have forgotten your password, please email technical support at support@faronics.com for further information. Include your license number and organization details.
If you are running a 60 day evaluation version of Deep Freeze and have forgotten your password, then enter the computer s BIOS and forward the system clock 60 days & restart.
I hope this helps, if it does, give me a big thumbs up!
Jun 28, 2011 | Computers & Internet
When my green egg gets to temp over 600 the lid becomes lose and falls off when you lift it. I've already broke one. Why is this
It sounds like a problem with the hinge springs, rather than the lid. One will usually break before you realize it has. Then the second one goes, before you realize it. And it's usually when you have the Egg heated to a high temperature. You should also check the steel band around the egg, that is part of the hinge system to make sure it has not been overtightened or is to loose.
The folks at Big Green Egg take this sort of thing seriously and are devoted to their customers. You should also contact them about this issue.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Big Green Egg Large All-in-One Grill /...
I cannot seem to delete the files from my Lacie hard drive. The message says that I have no authorization to the files.
use a boo table dos disk and use dos to delete these files, if you need more info on how to do , use a windows commander, or Norton commander 40
Dec 19, 2010 | LaCie Big Disk 500 GB Hard Drive
While watching a dvd, the computer freezes then makes me have to restart windows in a safe mode. this does not happen all the time, just after using the software for over an hour
If the computer freezes this may be a sign of bad memory in the unit. Powerr DVD would not be the blame for the computer freeze. also what could be the issue would be a video card failing to render the video. I would suggest you have this computer evaluated,, You could also try to recover the computer back to its factory settings if that does not work you know you got a hard ware issue.
Sep 29, 2009 | Dell Cyberlink PowerDVD Software CD DVD...
Leaks water into room
Try tilting the a/c to the back. In most cases the manfacture will seguest that the unit be tilted to the back slightely (no more that 20 degrees). That is what I would try. If that dont fix it let me know and we will try together and solve this problem. Good luck
Aug 24, 2009 | GE Heating & Cooling
Air conditioner leaking
Hi, There are no pipes, just passage ways on a window unit. It probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit through passage ways to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt or algae in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem. Since the tilt is right and it doesn't seem to be freezing, Maybe a temporary increase in tilt and a dropper of bleach at the base of the evaporator would do it. This will kill the algae and may unblock the water flow. NOTE: It may also cause stains on a carpet or floor if the bleach water drips onto it. If you want to pull it out and clean it, most units can be pulled out of the housing and sprayed with a water hose but you need to be careful not to get water in the electrical parts of the unit. They can be covered with plastic or foil. Make sure you unplug the unit before trying to remove it. You may have to remove some screws to remove it from the housing. Hope this has helped. kstfas
Sep 19, 2007 | Sharp AF-S120FX Air Conditioner
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Premier Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Premier Heating and Cooling Expert? Answer questions, earn points and help others
