Question about Dell 3100cn Laser Printer
DEll Drucker Problem 004-321
hab im Forum gelesen Sie hatten das gleiche Problem mit dem Drucker wie ich jetzt. Was war die Lösung?
Gruss Weitzter Willibald
Antwort erbeten auf info@landgasthof-weitzer.de
    Novelist:
  • 188 Answers
I am hoping that you have someone that can translate this for you. I can not read the actual text of your post, however, I do know the error you are questioning about.
see below:
This error, 004-321, is that the MCU can not receive the output signal from the IBT ( intermediate belt transfer assy) at the specified timing.
There are several possible causes for this.
1) the IBT unit is defective. even if it is new, in rare instinses, they can be out of the box defects.
try reinstalling the old unit and determine if the same error exists. If that error goes away, the new unit is defective. request an RMA from the supplier and replace with a known good one.
2) the IBT sensor is defective ( or dirty... toner dust obstructing sensor ). This sensor is located at the left hand side of the metal cross bar underneath the IBT when removed. Try blowing out the sensor with a can of compressed air. Be careful not to spray this at the toner cartridges directly as this will just blow more toner up into the air, and the fine toner dust should not be inhaled. I would suggest putting a paper towel between the sensor and the cartridges before using the compressed air for that reason.
There are other possible causes for this error, all of which are far more expensive to repair and even less likely to be the cause, as your printers were working before changing the ibt's out.
Good luck :)
( if you found this solution helpful in resolving your issue, please remember to rate the solution as "fixya"..
Thanks
Posted on Oct 10, 2008
Hello wie kann ich handy mit PC verbinden.was muss ich herunterladen?
1. Klicken Sie HIER. Dadurch werden Sie auf der Samsung Webseite Kies bringen.
2. Wenn auf dieser Seite, Blick auf die Links f?r die genaue Modellbezeichnung Telefon.
3. Klicken Sie auf diesen Link und laden Sie die Kies-Programm.
4. Nach dem Herunterladen Kies, f?hren Sie die heruntergeladene Datei und installieren Sie das Programm Kies.
5. Jetzt in der Galaxy S-Stecker an Ihren PC mit einem Mikro USB-Kabel (in der Regel mit dem Handy im Lieferumfang enthalten)
6. Die Kies-Programm wird automatisch gestartet, wenn das Telefon angeschlossen ist, oder Sie k?nnen den Kies Programm zuerst.
7. Sie werden in der linken oberen Ecke, dass es eine Verbindung herstellt zu sehen. Dann werden Sie M?glichkeiten, wie und was man zu synchronisieren wie angegeben werden.
May 04, 2011 | Samsung Galaxy S GTI9000 Smartphone
Hallo wie kann man die uhr bedienen
  • Ich nehme an, Sie haben die Cobra 2000 als das ist die einzige Cobra-Modell mit einer Uhr auf.
Um die Uhr auf sie diesen Schritten folgen -
Time Set - 3 Switches (zur Zeit eingestellt) Dynaalert - 3 Switches (zur Alarm-und Radio) Counter / Clock - 3 Switches (zur Anzeige auswählen)
TIME SET Time Set Switch - Drücken Sie diesen Schalter mit Stunden-Schalter oder Minute-Schalter zur Einstellung der richtigen Zeit.
Stunden-Switch - Durch Drücken dieser Taste gleichzeitig mit dem Schalter auf die richtige Stunde Einstellung zu erhalten.
Minute Switch - Durch Drücken dieser Taste gleichzeitig mit der Zeit den Schalter auf den richtigen Minuten.
Dynaalert (Wecker) - Depressing thr Schalter auf den ersten und dann über die Zeit eingestellt VERFAHREN (nicht in Betrieb) wird Ihr Wecker gestellt. Nach dem Alarm auslösen Schalter ist so um die Uhr funktioniert normal.
Alarm Switch - Mit diesem Schalter Ursache des Alarms zu einer vorgewählten Zeit ertönt. Release-Schalter, um den Alarm abzuschalten. Alarm wird auch gehen automatisch nach 1 Minute, wenn Sie nicht mit dem Schalter Freigabe wählen.
Radio einschalten - Drücken des Funkschalter wird das Radio dazu führen, dass wiederum auf der vorgewählten Zeit. Drücken Sie Schalter auf Radio auszuschalten.
Counter / Tine - Ist dieser Schalter bewirkt, dass der Empfänger Frequenz angezeigt, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Auto Switch - Ist dieser Schalter bewirkt, dass die Zeit gefunden, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Zeit-Schalter - Mit diesem Schalter Ursache der Zeit kontinuierlich angezeigt werden.
Tony
Apr 23, 2011 | Cobra Radio Communications
Hallo lieber Experte !!!!!!!! Ich brauche dringend Hilfe.Ich habe mein Passwort vergessen,vom spiel: My secret diary.Mein Handbuch habe ich auch nicht mehr,habs ausversehen weggeschmissen.Also,wie lautet...
Brauchen Sie einen Kredit?
Und Ihre Bank wird gegen Sie oder die einzelnen drehen, wie hier haben Sie
Gelegenheit, kontaktieren Sie uns heute
Everistusloanfirm2011@live.com für Ihre schnelle und zuverlässige Darlehen heute.
Ich hoffe, von Ihnen als Ihre finanziellen Probleme zu lesen, und Ihr Unternehmen
heute gelöst.
Mit freundlichen Grüßen,
Everistus
Nov 04, 2010 | Nintendo DS Lite
Hallo. Seit einigen Tagen habe ich in der Früh nach dem Einschalten des Acer Aspire 5630 eine falsche Systemzeit. Woran kann das liegen? Wie kann ich diesen Fehler beheben? Danke!!
Sie können dieses durch das rechte Klicken auf Taktgeber Ikone, im unteren rechten Werkzeugstab regeln. Auserwählt justieren Sie Datum und Zeit, justieren ihn hier. Sobald getan ihm mit einem Zeitbediener aktualisiert. Erinnern Sie sich an Tageslichteinsparung.
Mar 30, 2010 | Acer Aspire 5630 Notebook
Bei unserer Canon sehen wir kein Bild mehr auf dem Monitor. Man hat auch kein Foto wenn man abdrückt.
Ich hoffe, dass Sie mit den folgenden, wie ich nicht Deutsch sprechen, und ich bin mit Google übersetzer. Ein stecken Auslöser ist ein weiterer häufiger Fehler-Modus für Digitalkameras. Die Symptome einer stecken oder "klebrige" Auslöser sind sehr ähnlich zu CCD-Bildsensor Scheitern. Die Kamera kann Bilder aufnehmen schwarz (für Verschlusszeit fest geschlossen), oder die Bilder können sehr hell und überbelichtet, besonders wenn im Freien getragen (für Verschlusszeit fest offen).
Um eine Verschlusszeit fest zu bestätigen, legen Sie die Kamera in einem anderen Modus als "Auto", und der Blitz ausgeschaltet (Sie wollen nicht blind sich für den nächsten Schritt).Zunächst blicken die Linse und ein Bild. Sie sollten ein kleines Flackern in der Mitte der Linse sehen, wie der Verschluss öffnet und schließt. Wenn keine Bewegung zu sehen ist, dann haben Sie wahrscheinlich ein Auslöser stecken. Wenn ja, lesen Sie bitte diesen Link für weitere Informationen und ein einfaches Update, das helfen kann.
Mar 19, 2010 | Canon PowerShot A620 Digital Camera
Hallo, meine Camera wie oben funktioniert nur noch wenn keine Speicher- karte im Gerät ist. Mit Speicherkarte ist kein Strom vorhanden. Wo ist hier das Problem. Habe kein Geld für teure...
Ich bitte um Entschuldigung, aber ich bin mit Google übersetzer. Bitte schauen Sie in Ihrer Kamera CF-Karten-Slot. Ich vermute, dass Sie eine gebogene Nadel in es haben kann. Wenn ja, entfernen Sie die Batterien und Karte. Verwenden Sie einen kleinen / dünnen Juwelier flachen Schraubenzieher, bis die Nadel verbiegen wieder so nah wie möglich. Eine preiswerte Juwelier Schraubenzieher funktioniert problemlos. Ein weiteres Tool, benutze ich manchmal ist ein steifer Draht mit einem gebogenen Haken am Ende. Dies trägt dazu bei sehr flachen Pins erhalten begonnen. Nehmen Sie sich Zeit und verbrauchen viel Geduld (machen Sie eine Pause dazwischen, wenn nötig). Macht einfach weiter es nach oben und gerader einer "kleinen Menge zu einer Zeit". Was immer Sie tun, versuchen Sie nicht, um es mit einem Tastendruck entspannen, werden Sie nicht in der Lage, es zu tun.
Es muss nicht perfekt sein, nur so nah wie man es bekommen kann. Wenn es das Beste, was Sie es bekommen können, nehmen Sie Ihre Flash-Karte und "langsam" einfügen. Die Karte selbst ist fein-align des Stiftes. Entfernen Sie die Karte, und stellen Sie sicher, dass die PIN noch gerade ist. Wenn ja, setzen Sie die Karte und versuchen, die Kamera.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
Ich habe einen speedport W721V und weiss nicht wie ich µorrent zum laufen bekomme
Kommt darauf an was du meinst damit, daß es "nicht lauft". Am unteren Rand des Fensters von µtorrent sieht man in der Mitte der Statusanzeige einen farbigen Punkt. Wenn dieser ROT ist, hast du wahrscheinlich ein NAT-Problem (vorausgesetzt, du hast deinen Port in deiner Firewall freigegeben. Wenn noch nicht, dann solltest du es jetzt tun. Wähle einen Port im Bereich zwischen 49152 und 65535, der ist nämlich bestimmt frei).
Meistens kommen NAT-Probleme daher, weil der Router den Verkehr für unautorisierte Ports blockiert; das ist eine Sicherheitseinstellung, kann aber auch mit normalen Datenverkehr Probleme machen. Neuere Router haben oftmals die Unterstützung des UPnP Protokolls eingebaut. Schau dafür in deiner Routerdokumentation nach, wie du diese Funktion im Router aktivieren kannst. Danach setze in µtorrent unter: "Optionen" "Einstellungen" "Verbindung" "Aktiviere UPnP Port Mapping" einen Haken. Das farbige Symbol (NAT-Anzeige) sollte von gelb auf grün wechseln, sobald du erstmals eine eingehende Verbindung hast (natürlich wenn du einen torrent laufen hast!). Wenn es aber rot wird, oder du im Reiter "Protokoll" eine UPnP-Fehlermeldung erhältst, dann schalte UPnP ab und leite deinen Port manuell weiter. Sollte das nötig sein musst du den Empfangsport für µtorrent einstellen. Dafür unter "Optionen" "Einstellungen" "Verbindung": einmal auf den Knopf "Zufälliger Port" klicken, und notiere dir den vorgeschlagenen Port. Diesen Port musst du jetzt in deinem Router weiterleiten (forwarden). Du kannst aber auch einen Port deiner Wahl verwenden. Jetzt den Haken bei "Bei jedem Start von µtorrent einen zufälligen Port wählen" rausnehmen. Damit bleibt der Port immer gleich. Wie gesagt, idealerweise steht bei deinem Port z.B. '34250-34377 Unassigned' (wenn du z.B. den Port 34343 gewählt hast). Das sollte es sein, wenn du noch Hilfe brauchst lass es mir wissen.
Wenn diese Lösung geholfen hatt, bitte klicke auf RATE :)
Jan 28, 2009 | Computers & Internet
Fritz!BOX fon WLAN 7170
DHCP und FritzBox gibt öfters Probleme.
Ich würde eher meine Drucker auf DHCP umstellen als den Rest der PCs und die Fritzbox.
Bei HP - Druckern kann man das via InternetExplorer ändern.
DHCP vergibt zwar die IP´s automatisch, aber nicht dauernd neu.
Erst wenn die maximale Anzahl an Geräten erreicht ist oder ein komplettes Reset gemacht wird.
In meinem Netzwerk laufen 5 Rechner und 3 Drucker, verbunden über einen SMC - Switch, alles über DHCP. Geht problemlos.
übrigens: das ist ein englischsprachiges Forum, da kann eine Frage auf Deutsch länger bis zur Beantwortung brauchen :)
Aug 18, 2008 | AVM Computers & Internet
Dell 3100cn Laser Printer Logo
822 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
