Cruzer Mimi 256 MB stick Completely Dead! I woulde like to recover data from this stick, if possible. Is there a repair kit available?
  • don0614 Oct 04, 2008
    If the stick were operating, I have tools that could probably recover the data. This data IS important to spend a few dollars trying to recover it!
    Thanx
    Don Cardoza
    Scholar:
  • 155 Answers
It should be at least operating and receiving power to get data out of it.
If we're talking about very important data. You can try calling drivesavers.
Posted on Oct 03, 2008
Need recovery tool for creative mp3
http://www.snapfiles.com/freeware/system/fwdatarecovery.HTML
http://www.softwarepatch.com/software/smartrecovery.html
http://www.cardrecovery.com/
http://www.brothersoft.com/memory-stick-recovery-tool-59805.html
Any of those should help you recover any data on tour device which is essentially a memory stick.. just treat as such.
May 12, 2011 | Creative Technology MuVo Slim (256 MB) MP3...
Unable to recover password without loosing vital data, loaded on scandisk cruzer 4gb
The best way to go about this is to find a linux system as linux operating systems completely bypass the U3 security completely.
May 01, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Feb 14, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Data and bad sector Recovery software for 8 GB SAndisk
you can try some data recovery software. You can see
Recover data from memory card
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jan 27, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The memory stick pcb has fractured into two pieces
The cruzer does not need the case to work, just be careful how u handle it connect to your computer and get your data. hope this helps
Jun 13, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I want to upgrade my PC's RAM from 128 to 512 MB Is is possible to add only single RAM or two 256 MB RAM?
Depending on your mobo, you can do either, add one stick of 512MB or two sticks of 256MB. If you're sure you get matching sticks if your mobo is DDR capable.
Jan 03, 2010 | Intel Motherboard
My cruzer micro 4gb flash needs compression but I get the message drive not formatted. How can I recover the data without formatting the flash drive since formatting will erase all of my data?
You can run a data recovery app on the drive and attempt to pull off any data still accessible. I recommend the GetDataBack Data Recovery apps from http://www.runtime.org . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Aug 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Recover deleted files from Cruzer?
Since you are using Macbook, you can go to this program USB Flash Drive Recovery for Mac for help. If you are running a computer with Windows, go to Data Recovery for Windows. It should help you out.
Note: before recovery, DO NOT save more files to the USB drive.
Nov 23, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Nothing on my cruzer micro!
hai,
check that the files in ur flash drive is hidden or not.
for that in folder options change the view settings to view the hidden files.
still u cannot find ur files, use any file recovery software.
to help u find one click here
good luck
Please don't forget to rate or accept the solution
Jun 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Ram issues
Hi Mike,
take the working 256 meg stick out of the slot it,s in. and try it in slot 2 or vice-versa.
This will eliminate the possibility of the mainboard being faulty.
If you get a boot on both Ram slot channels, then your Ram is dead, or incorrect. Check that it,s compatable with the motherboard. i.e running speed 2700-3200-et,c and that it is the correct parity and voltage, as per required by the board/CPU.
Mike @ compurepair.
Mar 06, 2008 | Intec S848P Motherboard
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
