Question about Brother MFC 420CN All-In-One InkJet Printer
Difusser install Still Prints but getting a message to install difusser or out of difusser.
  • Brother Master
  • 4,338 Answers
The diffuser is the optical lamp that distributes the light which allows the image to be seen by the drum and consequently put onto the paper. Is is not something you install. If you get this message , it it a mechanical problem and it needs to be serviced.
If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
Thanks, Joe
Posted on Oct 14, 2008
Pump turns on but not sucking any water
Sure there is water in the pump toy start with?
If the pump element runs in air, it won't be able to move water.
Jul 17, 2014 | Grundfos Pumps Grundfos JPF-3 1 2 Hp 115V...
I have an older Hayward pool filter. Is there a link to dowload instructions for replacing or adding sand to the filter?
Here is how I do it. Open the top. Open the drain on the bottom to allow the water out. Remove the plastic water difusser on the top. With a small can, scoop out the sand. When you get to the laterals, remove them for inspection. The sand below the laterals if fine, it does not need to be removed. Put the plug back in. Replace any laterals that may be broken (probably none) Fill the filter with water to about 6 inches above the laterals ... maybe more. The water will protect the laterals from the new sand as you fill the filter. It will also help the sand to pack in around the laterals. Continue filling until you are about 3 inches below the difusser that will go on the top. Make sure you don't bury the little black hose. The purpose of the little black hose is to remove the air from the filter during operation. The hose should ultimately stick up into the inside of the top (cover). I think your filter takes about 300 # of sand. Double check with your professional pool supplier where you purchase your sand. I normally will fill the filter with water before I replace the top. You may want to put on a new "O" ring too ...
This new sand should last you at least 4 to 5 years in non commercial use. After that time, you may want to replace the top 4 inches with new sand.
Thanks for your question @ FixYa.com
Jul 06, 2011 | Hayward SAND FILTER, PRO SERIES
EARLEIR TODAY I REPLACED ALL MY FILTERS FILTERS AND TURNED MY STA RITE E GLASS II ON ....IT RAN FOR ABOUT TEN MIN......... SHUT OFF AND NOW IT WONT TURN BACK ON HAVE RESET ALL BREAKERS IS THERE A RESET...
First to be sure shut the breaker off then turn back on. Most breakers require that you do this for safty reasons. Check all your power from the breaker to the back of the motor with a meter. If you have power shut it off then open the pump by removing the steel clamp that goes around the pump. Pull the motor and back half of the pump away from the rest of the pump. Now remove the difusser, the white plate covering the impeller. Then try to spin the impeller. If it spins then try to start thr motor. If it goes then you have a problem with the impellor or the difusser. If it won't start at this point you probally have a bad motor and will need to replace it. I always recomend new but you can get a rebuildt. If it's the impeller that will usually be obvious. You can take it into your local store and have them match the parts and they will usually do the bench work for just the charge for parts.
I hope this helps, good luck.
Aug 31, 2010 | Sta Rite Sta - Rite 2hp Max - E Pro...
My refer is at 41 degrees just had the difusser
Maybe your evaporator needs cleaning, I'd check that.
Feb 03, 2010 | KitchenAid KSRS25IL Side by Side...
Color spots on screen. Yellow mid way on top and blue on bottom left.
this can be the dirt issue on difusser. Clean it properly. Moreover, if you have any appliance that contains the magnetic effect, remove it near the tv.
good luck
Feb 02, 2010 | Panasonic Televison & Video
Flame height on one burner decreased!
you need to clean your difusser for that burner,
its probably have gunk built up on it
Oct 05, 2009 | KitchenAid Superba KFRS271TSS Stainless...
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
How to Change the Headlights in a 2008 Lancer ES
You shouldn't have to remove the entire headlight assembly to change the bulbs; They should either twist out, snap out, or have a spring clip that holds the bulbs in.
Mar 31, 2009 | 2008 Mitsubishi Lancer GTS CVT Sedan
Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Nov 29, 2008 | Whirlpool Refrigerators
Brother MFC 420CN All-In-One InkJet Printer Logo
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
