Question about Panasonic Lumix DMC-LZ5 Digital Camera
Lumix dmc-lz5 replace battery
Hello
I like my dmc lz5 very much, durable, trustable...
First time problem here, replace batteries...
New batteries, they work fine in flashlight,even for longer time, but dmc-lz5 displays replace batteries.
After dismounting back panel, I have found inside a button-battery 1 mm thick 6mm diameter,
it turned out it is a special, rechargeable one, it gives 3 v, but it can use a charging voltage as low as 2.8 v.Earlyer I tought this was the problem- because I have used the camera with rechargeable batteries, (those give 2x1.2=2.4 v , less than 2.8 ).I bought alkalines, giving 2x 1.5 = 3 v , but after about 50 pics taken the problem is here again.Now i try to replace the button battery (type panasonic ml-614), hoping this is the problem.
Do you have some idea or similar case?
I've seen http://www.fixya.com/support/p468828-panasonic_lumix_dmc_lz5_digital_camera/manual-19774/page-92
http://www.fixya.com/support/p468828-panasonic_lumix_dmc_lz5_digital_camera/manual-19774/page-12
Thank You for taking time to reply
Gergo
  • 1 more comment
  • erdeigergo Oct 06, 2008
    Hello
    I have already tried a few brands,
    With fully charged rechargeables,now it doesn't even open lens.
    All batteries were tested and fully functional both in low and high power consumption devices.
    ButtonBattery not aviable yet
    Gergo
    Thank you for your wise and kind reply,
    But looking at the top line in my browser, it says FIXYA
    I just can hope this suggests that this is a place for people to help each other to fix things themselves, and not a place where it is proposed to buy a new one or go to the service station.
    I just can hope...
    that someone comes up with a solution,knowing the problem.
    Gergo Erdei
  • erdeigergo Oct 07, 2008
    Hello all
    Problem solved
    It was a weird battery recognition problem.
    It seems altough the right setting(double checked) for alkaline batteries the camera somehow remained in oxyride batt. mode but displaying alakline ni-mh - and thus missed the correct voltage.
    The problem solved inserting a pair of oxyride batteries,by this and changing batt setting to oxyride , then again to alkaline ni-mh . Since this it works fine
    After the service personnel recommendation, I didn't change micro button batt, no link with problem.
    Good luck
  • 3 Answers
Use Ni-MH batteries which has a capacity of 2500mAh or more try GP 2700mAh rechargeable batteries i get around 200 shots with flash on for all the 200 shots + switching it on and off occasionally.....
Posted on Dec 19, 2008
    President:
  • 2,712 Answers
Try replacing the button battery first and see if that helps...Some batteries simply just do not last as long as other brands. Try switching brands (for the regular AA batteries) and see if this also helps..
Posted on Oct 03, 2008
  • Swilin Sampson
    Swilin Sampson Oct 06, 2008
    I think the best thing to do in this case is to either get the camera serviced, or buy a new one, whichever is cheaper..
  • Swilin Sampson
    Well, it will require opening up of the camera, which I cannot do, as I am in Ireland! All we can do at Fixya is offer every possible troubleshooting step we can think of, but actual repairs will have to be done by the customer himself (I thought this was understood). One final thing you can try is to upgrade the firmware . You will have to Panasonic website and download the firmware for your camera. Instructions for upgrading the firmware will be found on the website itself.
    PS..Inappropriate rating is reserved only for solutions that have no relation whatsoever to the problem. For example, you ask me what is an apple, and I describe a banana, THAT is inappropriate. It is not a rating for a solution that does not work. I have giving you all possible steps that you can attempt yourself..surely that in not Inappropriate? I would be very grateful if you could at least revise your rating to Thanks For Trying. Although that is still a negative rating, its not so bad as an Inappropriate.
    Thank you for understanding,
    IrishDruid
Lz5 card does not work
Make sure you're using an SD card, 2GB and smaller. The DMC-LZ5 will not work with higher-capacity SDHC cards.
Dec 01, 2012 | Panasonic Lumix DMC-LZ5 Digital Camera
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
What is max size memory card for lumix dmc lz5
Although it's not the newest device out there, an SD card of 4gb would be more then suitable for it, check the manual for more info about the limitations which your device has:
Panasonic DMC LZ5 Manual
Dec 28, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
Where can I get a operators manual for my dmc-lz5
Click Panasonic Support to download instruction manual copy of DMC-LZ5 camera.
Thanks.
Dec 15, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
I have a lumix panasonic model DMC-LZ5 when it turns on the battary indicator indicats that the battry is empty although it is fully charged
This is a battery contact problem, the DMC's are horrible for it. Firstly as the previous answer said, take the battery out and clean the 3 copper tops (scrape them with a knife tip to remove ****) and secondly, make sure it is seating well into the battery cavity, you may want to pop a bit of tape on the back end of the battery so it is pushed in a little deeper by the door when it closes.
Apr 04, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
Video format on Lumix DMC-LZ5
I dont believe it is possible unless you use a converter during the save function. I can not do it any other way. If you figure it out let me know. But I would say it is time to upgrade for me. The new HD mode in some of the newer cameras is much easier to deal with for me.
Sep 23, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
Hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Jan 19, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
NO POWER
make sure u arent using any uber cheap batteries, cuze i used a pair of panasonic heavy duty and they died after 4 shots D=
Dec 09, 2007 | Panasonic Lumix DMC-LZ5 Digital Camera
Lumix dmc-lz5
Cleaned is not the problem. Most of the time it is poor battery. Just becuase the battery says it is charged means nothing. These cameras take a great deal of power compared to other AA devices.
Sep 29, 2007 | Panasonic Lumix DMC-LZ5 Digital Camera
Panasonic Lumix DMC-LZ5 Digital Camera Logo
420 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
