Question about Nakamichi Audio Players & Recorders
I have a Nakamichi TM-1 radio that is not working. When plugged in it will only hum, I cannot use the tuning or volume buttons. The digital display is not showing. The radio can only be turned off by unplugging the power cord.
Sounds like a boat anchor to me
Posted on Oct 12, 2008
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Preseting radio stations so i don't have to use the tuning dial everytime
Most radios let you set them like this - select bandwidth FM/AM then tune to a favourite station, find the row of numbered buttons under digital display (usually 1 - 5) then press and hold button 1 for a few seconds, the station will be set to button 1, so to speak. Repeat tuning to another station then press button 2, etc...some radios have up to 15 slots per band. How many stations do you listen to....
To recall station 1, press button 1 ..button 2.......... Red.
Apr 05, 2014 | 1997 Isuzu Hombre
I cannot find the ARI-Z button to my car delta car radio. the instruction is press the am button simultaneuosly with the ARI-Button. where is the ARI-Z button in the delta radio? tnxs
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
  7. If you lose your radio code, contact your Audi dealer.
Other Preferences & Configurable Options The following is the procedure on how to access some other preferences that you may set in the Audi Delta CC radio.
  • GALA and Turn-on Volume Settings
    1. Turn off radio.
    2. While pressing and holding the TP button, turn on radio. "GALA" will be shown in the display.
    3. To select the speed at which GALA activates, press the tuning up (up-arrow) or tuning down (down-arrow) buttons to the left of the volume control knob. The display shows the following:
      __' Highway speed
      _'_ City speed
      '__ Slow speed
    4. To save the setting, press both the tuning up and tuning down buttons simultaneously. "GALA" disappears.
    5. Press the TP button briefly, "VOL" appears in the display.
    6. To increase or decrease the turn-on volume, press the tuning up or tuning down buttons.
    7. To save the setting, press both the tuning up and tuning down buttons simultaneously. "VOL" disappears.
    To activate GALA, push the Treble control knob to let it spring out. Then, pull it out one more detent, and then turn the knob to the right. To deactivate GALA, do the same except turn the knob to the left. Push the knob back in when you're done.
Oct 05, 2011 | 2001 Audi A4
Lost code for 1996 toyota prado radio l had the battery replaced now the radio displays a sec sign
for our Toyota Prado 2001 01, after the battery had been removed SEC was showing on the cd / tape / radio display. To remove the security SEC warning, find the last 3 digits of your VIN number (under the hood) hold down the "TUNE" button and then press "1"
Then use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number.
Quickly hold down "SCAN" button, the radio will power off, then press the volume button to turn it back on.
-I accidentally held down "auto" before holding down scan, I don't think auto has any part of fixing this (just an error on my part) but if the above doesn't work, you could try hold AUTO down after entering the digits then hold scan - just as I did.
SEC has now been removed, enjoy your radio!
Feb 08, 2010 | Car Audio & Video
Setting the clock in a 1987 Dodge Dakota
First things first, if you havent already done so, check the owners manual. If you lost it or dont have one, i suggest 1 of these 2 procedures:
1.) Next to the radio, there should be 2 little holes. They are actually buttons. One of these has hours or "h" above it, while the other is labelled minutes or "m". Use a pen to press those little buttons to set the correct time.
OR
2.) Use the knobs to tune the radio (AM/FM and volume) to set the time. This is how it works:
-Press and hold the Time button
-The "hours" on the display should flash
-Turn the radio tuning knob to set the correct time
-Press and hold the tuning knob
-The "minutes" on the display should flash
-Set the correct time
Then you should either wait for it to stop flashing or press the time button to set it.
Jul 30, 2009 | 1987 Dodge Dakota
Setup radio presets
1. Navigate to your favorite station
with the UP/DOWN buttons.
2. Press MEMORY once. The
preset choice will go to the next
available one.
3. Within 5 seconds, press
MEMORY again to save the
current frequency as a preset,
or else use the UP/DOWN
buttons to fi nd another preset
number, then press MEMORY
to save it.
4. The UP/DOWN buttons usually
tune the frequency, but when
loading the presets, they navigate
the presets.
Jan 15, 2009 | Nakamichi SoundSpace 5 Shelf System
Where can i find the manual
Hey! I found and printed out the manual for the RCA 3740 Cd? radio?alarm ...
RETREVO
You will need to register just as we have had to for Fixya. But at least the answers are there. Gotojo
Dec 11, 2008 | Audio Players & Recorders
Nakamichi TM-1 Clock Radio
OK YOUR UNIT IS BAD YOU NEED TO TAKE IT TO A RADIO REPAIR SHOP TO FIX THIS I DON'T KNOW OF ANYONE IN MY AREA THAT STILL HAS THESE...
SORRY FOR THIS..
BUT LOOK UP RADIOS IN THE YELLOW PAGES THAT'S ALL I HAVE TO OFFER I WORK ON RADIOS MYSELF AS A HOBBIE ALSO COMPUTERS..
Please do not open it...
VOLTAGES INSIDE...
SHOCK HAZARD...
TAKE IN SOMEWHERE AND GET IT FIXED.
Nov 01, 2008 | Audio Players & Recorders
Change the time
make sure the time is displayed and press the "set" button. once the time starts flashing use the "preset" buttons to set the hour and the "volume" buttons to set the minutes. press "set" again when done.
Mar 14, 2008 | Nakamichi SOUNDSPACE 1 CD Player
190 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
