Question about HP LaserJet 4600dn Color Printer
1/2" yellow line appearing in the middle of a background colored page
When using the printer with a full single-colored red background, a 1/2" yellow-colored line appears running horizontally across the page. When using a dark blue background, a lighter blue line appears where the yellow line should be. When using a green background, the line is filled in with green and is barely visible but can be noticed. What is producing this and how do we get rid of it?
  • 661 Answers
Sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Posted on Oct 03, 2008
MFC-9840 printing Yellow/Red/Blue strips in background. Any ideas why?
This is caused mainly by leaving the Corona Wire sliders anywhere other than where the arrows on the slider meets the arrows on the Drum Units. This leaves solid lines of colour down the length of the page (one per colour with the slider in the wrong place) if it is leaving more than the single line on the page it is probably leaking cartridges.
These particular cartridges are known for their ability to leak badly (OEM and Remanufactured cartridges do it). The only option for a leaking cartridge is to replace it and clean out the machine with a lint free cloth preferably a 'Toner Grabber' cloth. If you nee one of the toner grabber cloths then talk to your local cartridge refilling place for one. If they refil toner cartridges there then they probably have them or can suggest a different option.
Aug 12, 2014 | Brother MFC-9840CDW Laser Printer
Laserjet hp ce3525dn has a yellow background and yelow layer over my color printing
1. Scroll to and touch Administration.
2. Scroll to and touch Troubleshooting.
3. Touch PQ Troubleshooting.
4. Touch Print.
Chk PQ test pages, if yellow color arrests entire page?.. Two reasons
1. Yellow cartridge.. ( swap with another one & chk )
2. Chk yellow cartridge contacts, clean them with isopropyl alcohol.
Chk base contacts, broken?, dis placed?, not contacting?..etc ...Remove & refix DC controller board...
May 07, 2014 | HP CP3525N Color LaserJet Printer
Color stain
Laser, inkjet??? Model Make ??? You need to be more specific.it makes a difference on the type of ink used.
Sep 06, 2012 | Samsung Clp-325 Colour Laser Printer
Yellow and blue colors disappeared.
Click Here!! For my how-to on how to fix clogged printer cartridges.
If that still doesn't help, Try printing a 'test page' in your printer settings.
If that still doesn't help.... Replace!!
Hope this helps!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
May 23, 2010 | Apple HP DeskJet 940c InkJet Printer
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Seems to print a red or yellow line down the edge about 1 to 2mm wide, prints black fine. All toners over half full. Test page seems fine but can see red line along edge.
What ever color the line is you need to replace that photoconductor unit. They can be ordered from a Ricoh dealer and come with instructions for installing.
May 04, 2008 | Ricoh Aficio 3800CMF Laser Printer
When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
Jan 17, 2008 | HP LaserJet 2840 Printer
How do I reset the ink levels?
Well, theres the problem. Most printers can remember up to three cartridges. That includes color & black. The best way to put it is that each cartridge has a"funger print" that the printer can read, and estimated ink levels can be gaged. There is a way to "reset" the cartridges, but i do not have the document on me. Please email steve@nicesites.org and I'll send it today. I'm not saying it will work 100%, as the reset method is geared for the 56/57/58, but who knows right?
Jun 19, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP LaserJet 4600dn Color Printer Logo
300 people viewed this question
Ben Johnson
