Question about Nikon Cameras
Is there a way to shut off auto flash when I use manual programs on the D60?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Yes. Simply press the flash down until it clicks into place.
Posted on Dec 30, 2009
D60 flash won't pop up
Please set the MODE to P (Programmed Auto) In this mode YOU control the flash, not the camera. Inside where it is not bright. Set your ISO to 800 and take a photo indoors with low light. Then pop up the flash and do it again. P lets you take a photo with the flash down or UP it is the only mode I suggest most people should use. :)
Jan 15, 2017 | Nikon D60 Digital Camera
I have a nikon d60 and cannot get the pop up flash to work, any help would be appreciated.
there is a button just to the left of the flash on the camera that should pop up the flash or if you are in auto mode it shoud pop up by itself.. if these do not work then your flash is stuck and you could just pull up in it and it should open but I dont recommend that just in case you break it.. but I have done that several times
Nov 13, 2012 | Nikon D60 Digital Camera
What setting should the camera be on for an
That depends on the flash. If it's CLS-compatible (Nikon SB-400, SB-600, SB-800, and SB-900) you can use it in any exposure mode (except flash off, of course). The easiest flash mode is Auto-TTL, though some of the other modes will give you better control under certain situations.
If it's not CLS-compatible, then you'll have to take it off Auto-TTL. If the flash has a sensor, you can let the flash control itself (assuming it's at the same distance from the subject as the camera). Otherwise you'll have to go manual.
May 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Nikon d60 When I try to take a picture with the
That is a problem that has to do with the Flash...make sure your flash settings are not turned on. If the flash can't find an image...it rotates and usually never finds the image. It's reading in a Flash mode.
Mar 25, 2010 | Nikon D60 Digital Camera
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Lens will not auto focus with flash up
Not sure of you camera model, but the flash will fire momentarily when you try to focus indoors as there is not enough light for the auto focus to work. This is so the camera can determine a distance from the subject to the camera. This is called focus assist (ref to your manual). It will work outdoors as there is enough light and contrast for the focus to work.
Kit lenses included with the camera are notoriously known not to focus well in dark conditions.
Oct 11, 2009 | Nikon D60 Digital Camera
Have a nikon d60 and the flash will not go off even when in a dark situation. Pops up but no flash?
if it pops up then the sensor is working and the mechanical parts are working,
Next is manual force flash test, if is manually flashes, the bulb is good else replace the bulb.
Sep 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Imagines are dark even in bright light
the flash settings should have been kept in auto mode.if you want the flash always.normally, there is a button near the lcd screen, with the symbol of a lightning flash. when you press it once it sets the flash mode to auto, second time it sets it to "flash always on mode", third time "flash always off" mode.you can refer this process in instruction manual also.thanks for using fixya! please dont forget to rate my solution.
May 29, 2009 | Canon PowerShot EOS D60 Digital Camera
Cameras Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
