Question about Sony KP-61HS10 61" Rear Projection Television
Sony KP-61HS10 61 in. Rear Projection.
How do i get into service mode on my ty....kp61hs10 sony. I tried pressing
display,5,vol+,power,...... but it doesn't work.
  • pauljohn50 Feb 21, 2009
    I also tried the buttons to get to service mode and can't. The buttons work individually. I start with power off or with standby timer flashing.
  • 10,594 Answers
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Posted on Oct 03, 2008
Turning closed caption on Sony kp61hs10
Your power source seems to be the problem, you will need to replace that part.
Jul 18, 2010 | Sony KP-61HS10 61" Rear Projection...
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Sony Wega Model #KP51WS520
Press in order on the SONY remote "display - 5 - vol. down - power" .that will show diagnostics indicating 9 Zero Cross Detect . You shoud take it to a servicer.
Oct 18, 2009 | Sony KP-51WS520 51" Rear Projection...
Wont turn on,9 blinks on stand by
9 is Zero Cross detect. It would require a couple parts replaced on the G board or replace the G board or watch it right now till you get it fixed....kinda..Just press in this order on the sony remote "display - 5 - vol.down - power"
Oct 11, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony kp57ws500 no picture
Try the Self-Diagnostic Mode- Press Display,5 ,vol-, power TV should come up with codes which are trying to tell you whats wrong with set. Let me know what happens ?
Jan 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Sony rear projection tv kper43m31
All Sony projection TVs have the same remote key sequence to get into the service mode:
display - 5 - volume(+) - power
C-Dog
Feb 09, 2008 | Sony KP-61V90 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
362 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
