Question about InFocus POWER SUPPLY CORD Multimedia Projector
Infocus projector power supply dead
I have several Infocus projectors (X1,X2, X3 models) that have blown the power supply. A couple projectors blew the power supply when my home had some furnace smoke issues.
I found two bad 2SK3568 FETs bad on one X3 power supply that had also blown the soldered in fuse. I bought a replacement X3 projector that apparently blew a different portion of the power supply (only the fan runs; no lights or any other function). Does anyone have power supply schematics or have any repair history/advise for what usually goes wrong with these units?
  • 2,237 Answers
The caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Posted on Sep 04, 2009
    Champion:
  • 205 Answers
I believe you can contact infocus for them. They have been generous with these in the past, good luck
Posted on Jul 07, 2009
Lamp burned out on X1 infocus projector, Replaced lamp, new lamp stopped working in about 5 hours, got another new lamp and it does not light at all. Still blinking 3 red blinks(saying the bulb is bad)
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
Jan 08, 2010 | InFocus X1 Multimedia Projector
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
Jul 12, 2009 | InFocus X1a DLP Projector
Doest function.no image projection,fun does not function
fuse on ac filter board. if that's ok, there is a power supply issue.
May 31, 2009 | InFocus PROJECTOR LAMP, Projector Lamp FOR...
Infocus projector power supply parts
you won't find schematics for them. infocus had their boards made by someone else who now no longer makes boards. it's usually the caps drying out that causes power problems.
Nov 03, 2008 | NEC VT670 Multimedia Projector
Ballast
you have to go to an infocus authorized service center. you may be able to purchase it from them without having them put it in. check the infocus website for an asc. but for reference, the part # for the ballast/power supply is 520-0126-00 if there is a "0" in the 5th to last position in the serial #, and 520-0143-00 if it's an "a" in the 5th to last position.
Sep 29, 2008 | InFocus X1 Multimedia Projector
PLEASE HELP!!
It also depends what part you need because although the 3 models look similar none of the parts are compatabile with each other except maybe some body parts and the X1 and X2 share the same light tunnel but it would be a risk to assume that the light tunnel from a used model is OK. The only 2 models that share the same parts are the X1 and SP4800. The X2 is brighter and the SP4805 has a 16:9 native ratio.
Feb 11, 2008 | InFocus ScreenPlay 4805 Multimedia...
X2 board
ebay has several that need bulbs... just a thought here is one of the item numbers Item number: 270207032811
Jan 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus x2 dose nothing
Assuming the power outlet and cable is OK the most likely problem is the power supply and needs to be replaced.
Dec 06, 2007 | InFocus X1 Multimedia Projector
1,762 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
