Question about Electrolux Vacuums
Electrolux ambassdor will not run after pluggen in
I used my sweeper about three weeks ago and it worked fine, and two weeks after that it will not work. We have plugged it into every outlet in the house. Nothing works.
  • 438 Answers
Greeting from GoVacuum,
On all Electrolux canister vacuum cleaners, there is a kill switch, that will not allow the machine to turn on without a bag in it. Sometimes when replacing the bag, the bag is placed in a position where the switch is not being activated.
When you open the bag housing, it should look like this;
You'll notice in the bottom right corner of the bag housing, the kill switch to the vacuum cleaner.
Try plugging the vacuum cleaner in, and while you are pressing this kill switch down, turn on the vacuum cleaner. Does the vacuum cleaner turn on/off when you push/release the kill switch? If it does, simply just get a new bag, and make sure that the new bag is covering the kill switch, and close the door of the vacuum cleaner.
If it still doesn't start, let me know and I'll try to help you diagnosis the machine differently. I'd say that 6 out of 10 times, this kill switch is the problem.
I hope this helps you. Please email me with any questions, or if this fix doesn't make your vacuum work. I really enjoy sharing my passion, and expertise in repairing vacuum cleaners.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 03, 2008
My hand hoover is not sucking up
This is something I actually did with my Electrolux canister "SWEEPER HOSE" and yes, I know it sounds weird, but it worked. First of all, check for obstructions in the hose. If the hose is clear, then detach the HOSE from the sweeper and run water through it and see if there are any leaks. (If a hose has an "air" leak it will not be able to "suck" as well). Drain out the water and let it completely dry (inside and out) before reattaching it to the sweeper. Tape over the leak with duck tape or Gaffer's tape. My Electrolux sweeper hose had to be completely wrapped with tape (from one end to the other), but wow it really worked. The sucking capacity was increased tremendously. I hope this helps.
Dec 07, 2014 | Hoover Vacuums
How often do I change the filter on my Electrolux Jetmaxx
I can't answer that question, only you can....How often do you change the filter?
Now if you wish to know how often you should change the filter
every six months to a year depending on use.,,,once a week use- every year.....two or three time a week-every six months
Aug 09, 2013 | Electrolux Vacuums
The carpet sweeper on my electrolux stopped working....used it for a little bit and then it just stopped
Make sure the brush is cleared and clean, press the reset button, and try again.
If the motor runs, but the brush doesn't turn, it's likely due to a broken belt. Have it replaced by someone who knows what they're doing.
I strongly recommend taking it into an authorized shop.
Dec 04, 2010 | Electrolux Vacuums
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
http://www.aerushome.com/storelocator/
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Oct 12, 2010 | Electrolux Central Vacuum
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Joe
Nov 19, 2009 | Electrolux Vacuums
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Eleectrolux canister sweeper power switch
There should be screws holding the handle asembly on to the top. One near the from, another by the handle, then slide the door near the back, there are 2 more screws there. with the handle off, you can get to the switch. Hopefully you can fina a replacement, alot of parts for the older Electrolux is No Longer Available.
Feb 12, 2008 | Electrolux Guardian Bagged Canister Vacuum
Twenty year old Electrolux canister swith stopped working
What switch? If the switch is inside the tank, open it from the underside with 3 screws.
Nov 30, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
201 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
