Question about Canon PIXMA iP2000 InkJet Printer
Canon ip2000 reset ink absorber
Reseting ink absorber counter
    President:
  • 2,712 Answers
Waste Ink Counter Reset:
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanent
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
"After service mode Pls use software for permanent reset"
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 03, 2008
The ink absorber is full on my Canon IP2000 ink jet printer. How do I empty it please?
The waste ink absorbers are a pair of pads on the sides of the carriage near the bottom of the printer. You need to open up the printer (pop the top off). It is just clipped into place and held by its own pressure (you can usually see how it's held in). Unscrew (if needed) the ink carriage (leave the cartridges in place) and push it out of your way.
Wear gloves and have plenty of newspaper or something handy. Pull the pads out and rinse them clean (running water works well). Blot dry or let them dry in the sun. Use a hair dryer to get the last bit of moisture out if you are in a hurry. Then reassemble the unit. Then reset the counter for the waste ink tank.
To reset the counter:
1 - press resume button and then press power button
2 - realese the resume button and press 2 more times then realese both
3 - press and release resume 4 times and power 2 times...
I hope this helps.
(under normal use, the waste ink absorber is supposed to register a full counter at the expected end-of-life of the printer. Additional failures may happen soon.)
May 20, 2010 | Canon PIXMA iP2000 InkJet Printer
How do I empty the waste ink absorber on a canon ip2000
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 12, 2010 | Canon PIXMA iP2000 InkJet Printer
My waste ink absorber is full on my canonip2000. how do I fix this
Dis-asemble the printerr. Find the blotter felt absorber. Replace it or spend a lot of time rinsing it out till it becomes a light grey color and re-install it. Use the printer maintenance software for your printer to RESET the ink counter within the printer.
Oct 13, 2009 | Canon PIXMA iP2000 InkJet Printer
Ip 2000 waste ink absorber full
You need a shop to replace the ink absorber and reset the counter. The absorbers are under the print engine and cover the entire bottom of the printer.
Sep 28, 2009 | Canon PIXMA iP2000 InkJet Printer
Ink waste absorber is full. Canon IP2000. How do I repair it?
Well, at some point you will need to either replace or wash the absorber pads in the printer - but you can reset the warning as follows:
1) Turn the printer off
2) Press and hold the <resume>button
3) Press and hold the <power> button
4) While holding down <power> release <resume>
5) With the power button still held down, press <resume> twice more
6) Release the power button
7) Press and release the <resume> button 4 times
8) Press and release the <power> button twice
At this point, the printer should come back online with the waste ink warning reset
Personally, I would only do this once before actually changing the ink absorber pad...
Aug 31, 2009 | Canon PIXMA iP2000 InkJet Printer
How will i clean the ink waste absorber and reset it
use this link click here
this wil help you in cleaning the waste ink
you can also take halp of the following link
Jul 27, 2009 | Canon PIXMA iP2000 InkJet Printer
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
How do I reset the printer after washing the ink absobers
how do i clean the ink waste absorber of canon pixma ip2000 printer
Mar 24, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon iP2000 Waste Ink Absorber - where is it for washing and replacing?
I found it under my ink cartridges in my Canon iP2000 printer. Trying to losten it for cleaning, it came out in my hand, I washed it and replaced it with a tiny amount of glue. After resetting the program, it is working again.
Feb 11, 2008 | Canon PIXMA iP2000 InkJet Printer
Pixma ip2000
waste ink absorber is full what can i do
Nov 29, 2007 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
1,550 people viewed this question
old marine
old marine
Corne Viljoen
