Question about Mitsubishi VS-45605 50" Rear Projection Television
Mits VS-45605 Picture Jumping - See video
I have a Mits SV-45605. It was built in 1999. The picture jumps almost in a circular pattern. Here is a video link of the current picture.
What is the problem with this television? Could it be a problem with the PIP card that can be bypassed. I have looked at the capacitors and they are not bulging though I have not checked them with a meter.
http://www.youtube.com/watch?v=x0UCel81PYI
Yes, it is a Ms. Pacman game video you'll be looking at.
Thanks for you help and comments.
  • 1 more comment
  • jmwoodward1 Oct 08, 2008
    I have the exact same problem... The thing i know that it is NOT is a pip module problem. I would really like to get my TV back into working order.... I love this TV. Help would be greatly appreciated.
  • zmmatt Dec 03, 2008
    Older Timer, where exactly did you put the fan? I have a similar problem, but i dont know where in the rear of the case, or where to aim the fan...
    thanks!
  • gg5870 Jan 26, 2009
    I just got the Mits VS-45605 given to me and it looks identical to the youtube video posted above. Is it a difficult thing to repair? Can I find a step by step process with pictures that would walk me through repairing it?
  • 1,512 Answers
Hi Jim and seirig
The PIP module(problematic with this model) can be removed and bypassed, there are guys on ebay selling kits to do this. You probably DO have capacitor problems in the vertical stages(as is the problem with the PIP module also). They do not always "bulge" as an indicator of failure. Often they just leak out. If the bulge occurs about a safety vent stamped into the top of them means they have overheated, and the stamped vent is meant to rupture to prevent them from exploding. If there is any white residue on the board or corrosion about any caps, this is casued by them venting on the bottom side instead, then they have failed. if they move about easily then their connecting legs, they may have corroded off up inside the can of the cap itself. Sometimes they can appear physically AOK, and be faulty. Checking them with a meter is really the only sure way of determining a caps worthiness. It is a common problem with any electronics these days. They just dont build them to last. Surface mount capcitors actually have a shelf life even in storage!! Replacing all the caps in a stage to resolve a problem like this is often gives the best result. One failing cap can put pressure on others, and the overheating issue may reoccur. Best to get quality brand parts to replace failed caps. These guys are everywhere in the world, and easy to navigate, just search for you part :)
A FixYa is a good reward for my time to extend this advice to you. If you have more questions, I am also happy to attempt to answer them for you. Cheers
regards
robotek
Posted on Oct 18, 2008
It is caused by some overheating. I solved the problem by placing a fan (small) in the rear of the case. I run it when the unit is on and all of the lines disappear. Turn the fan off and they reappear. Simple, eh??
Posted on Oct 24, 2008
Our HD input suddenly went out.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
May 25, 2017 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi
This is a case of bad capacitors in the PIP (picture in picture) module. If you have any electronics repair experience, you should be able to do the repair yourself. Here is some more detailed instructions:
http://forum.eserviceinfo.com/viewtopic.php?p=59404#59404
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
No Picture on Mitsubishi v45605 rear projection tv
If it works the way you have it setup now, leave that way. Plug all your video sources to the denon if possible and leave it that way.
If the denon has the feature to change channels like a cable converter then you can use it or if you still have a VCR you can also use it as a tuner just to tune the cable channels and use the audio/video outputs from it to the TV or denon receiver.
The tuner might not even be available anymore and if it's, is expensive.
Good Luck.
May 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs 45605 no picture
yes if the tuner is out and you want to save some money then running an external set top box or your denon are fine. more often than not you will also have better picture quality.
May 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Jumping picture
Resolder the vertical output IC and the vertical yoke connections on the main PCB
Mar 16, 2008 | Mitsubishi VS-45607 45" Rear Projection...
CS-27403
Older Mits TV's have a PIP circuit board that fails,upsetting the video....here is the solution....
1) Remove PIP PC board ..... discard
2) pull chassis... on underside of main board, locate VP plug
3) Using 22mf 50v NP capacitors, connect pin 5 to pin11
and pin 7 to pin 9......
large pix stable.....but no PIP box.....PIP PCB NLA......
.................T.
Jan 27, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
385 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
