Question about Digital Video Systems Plenio VXA-3000 GPS Receiver
Reset Hi there I just got the GPS PLENIO VXA3000 and when i started de device i got pop uo window fatal error ( Memory card is write protected! application will shut down. and i cant get GPS to work. so pls i need some help thanks
  • power_agg64 Apr 04, 2009
    i bought this item from usa but i still in malaysia now so how to install malaysia map ( map king)
Hello, I had the same problem, I just go mine to work. First you have to have a computer that is able to accept the sandisk (sd card). Make a new folder. Then go to dvssales.com and there you can download the NK bin file. Then I took the original sd card that came with it transferred everything to the new folder. After the Nk file downloads I gave it the name Nk bin file. You have to go into search and find the Nk bin file and transfer it to the upgrade file in your new folder. Then I deleted the original sd card and then took everything back from the new folder. Make sure on the left side of your disk is in the up position. It will be white if it is in the down position, it is locked, that is why the write protection occurs. Any more questions feel free to write
Posted on Apr 18, 2009
  • 29 Answers
Try Removing SD Memory Chip From Unit, Remember What Side
of SD-Chip Faces Forward, Slide The SD-Chip, White Tab To
Unlock.
If This Fails
www.dvssale.com
Call Dan Kim 408-970-3387, DVS-Tech Santa Clara, CA
Email dankim@dvs.co.kr
Email kimus@dvs.co.kr
I Own One Myself, Just Upgraded to 2GB SD Chip, Reloaded Software w/Map Ugrade
Still Working Fine
jeffreydrescher@Bellsouth.net
Posted on Jan 15, 2009
MobileNavigator
Need Plenio VXA3000 OEM Files/Maps?
Jeffreydrescher@Bellsouth.net For Login & Password
Files Located @ MS SkyDrive/NAV-360 No Threats Found
Plenio Serial Number Required
Feb 02, 2014 | Digital Video Systems Plenio VXA-3000 GPS...
It works intermittenly
3) The LED turns on or flashes red during initial boot up :
When the temperature inside the car is too high or too low, the red LED flashes. In this case,
follow the steps below.
Turn the product power off and ventilate the car to return to normal ambient temperature.
Turn the power on after a little while and observe the LED color.
If the red LED still flashes under normal temperature, contact customer service.
Ref: Plenio VXA3000 Users Manual Pg 5/6 1-4 Troubleshooting
DVSSynchrome_VXA-3000_UserManual.pdf
Download Files At MS Skydrive Email jeffreydrescher@Bellsouth.net For
Login and Password
Dec 23, 2013 | Digital Video Systems Plenio VXA-3000 GPS...
MicroSD card has "fatal errors"
hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
Jan 08, 2010 | SanDisk 8GB microSDHC Memory Card with...
The same fatal error i have now
I dont see the model mentioned....
Most fatal errors relate to map glitches. If this unit has an SD card and it somehow pops out for an instant, such an error will be produced. Just reboot it with the card back in place.
If it is in memory then your maps have been glitched. Try updating .
Thanks for using FIXYA Please rate our help to keep the FREE service online++++
Sep 19, 2009 | GPS
Plenio VXA-3000 GPS Navigation System Memory Card Reader
Do Internet Search Google/yahoo for a
SD memory chip Card Reader, will most likely support
other Memory Chips Used Today, connects to your PC via
USB Port. Aprox $25.us
Need Tech Support?
Dan Kim DVS Sales {OEM-Plenio-Rep}
408 970-3388
www.dvssales.com
Dec 28, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
SD card reader seems to be dead
Need Tech Support?
408 970-3388
www.dvssales.com
JEFFREYDRESCHER@bELLSOUTH.NET
Plenio VXA-3000 Owner
Forget The Nail, Plenio Is Not Detecting SD Memory Chip, Sound's Like It Is Not Fully Seated
in Reader On Plenio, Call Kim
Sep 08, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Plenio GPS 3000
Plenio Is Litttle Picky On What SD-Chip To Use, I Just Upgraded Mine To 2GB SD-Memory
Chip Purchased From Walmart, Mgr Name Is a PNY, Black and Gold Display Case, also
Say's OPTIMA SD Ultra High Speed, Mgr Bar Code# P-SD2GB-FS [On Back Of Display Case]
During My Upgrading to 2GB Chip, Using Plenio-OEM CD," Navigation Map Data Base" DVD-ROM
Version 4.0. Had same problem,
Using Plenio Folder on PC " C:/Plenio/V-Up Pro 3000/VUPro3000.exe, checked box, SYSTEM UPGRADE, Selected SD Memory Drive, [My PC Was F:/], then software should detect SD-Chip
and Display Free memory Size, If So, Then Select Next, Should Take Aprox 20 minutes to Complete
Installing Plenio Software From Your PC to SD Memory Chip.
I'am Sure That IS How It Went For You, Mine Did Not Work For Navigation Either, Everything Else Was OK.
Take Your 1GB Chip And Copy To Your Hard Drive, ie; C:/Plenio/OEM_Plenio_1GB_SD
[Good To Always Have A OEM Backup]
From Windows Explorer Locate This Folder Name On The 1GB SD Chip Directory: MobileNavigator.
In This Folder, Locate File: Device.cfg & MobileNavigator.exe & rdat [No File Extension Displayed]
1] Copy These File's To Same Folder On Your 2GB SD Chip.
Your System Now Has Knowen Operating System Installed and should work like before,
might want to recheck your personal setting's.
I also noted using Plenio Software, I could not Check-Box "OS Upgrade" I think this is why
It Did Not Work. Still have to ask Plenio-Tech About This.
www.dvssale.com
Contact Dan Kim [USA] 408-970-3388 office
I also Noted CD I have Installed Larger Map File Size Than The Preloaded 1GB-Chip Has On it.
located in the "Cities" Folder, file: iusa_110mb_en_standard_cg.cdt 114,232KB
CD Ver 4.01 Installed this File; iusa_180mb_en_cg.cdt 184,145KB
Also Came Up Somewhere With Plenio a: iusa_50mb_en_cg.cdt 48,258KB
I'am Not a Plenio Tech-Rep Just A VXA-3000 Owner
Also Installed 103 MP3's and 20 .bmp Pics/Slideshow, had 480KB Free Memory Left
jeffreyDrescher@Bellsouth.net
Aug 02, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Pleino v-300
try turning it off, removing the memory card, then rebooting with the memory card NO installed, after it fully boots, turn it back off, reinsert the memory card and boot it again, it should be fully reset.
Apr 04, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Fatal Error Message
I have an older one of these with the AV connections. once in a while it does not see GPS signals. If I exit navigation and from the main menu select setup, I can reset the GPS and then go back into navigation, this seems to cure the issue but it may return. I think the root cause is a low memory battery in the unit.
Nov 08, 2007 | Fine Digital FineDrive 400 GPS Receiver
Digital Video Systems Plenio VXA-3000 GPS Receiver Logo
609 people viewed this question
Top Digital Video Systems GPS Experts
Will Halftowaite
Are you a Digital Video Systems GPS Expert? Answer questions, earn points and help others
