Question about Panasonic PanaFax UF-8000 Laser Fax
Leading edge I have a Panafax 8000. When sending a stack through adf each sheet as it come out gets knicked on the leading edge. I can hear it knick and see the knick but i can't see where its getting knicked. i've taken the adf apart and still no luck. Do you have a clue. daveis@sbcglobal.net
    Genius:
  • 2,120 Answers
Yes,
it's whacking the metal guide plate on the bottom below the white reference strip., I have had to gently "reform" the guide by opening up the space with a large screwdriver..
Posted on Oct 03, 2008
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
What to do about the ADF pulling too many sheets through?
Make sure the pick up roller is free of paper dust. You can get cleaner paper at an office supply store. It is sticky on both sides and will remove paper dust from the surface of the pick up roller.
Aug 21, 2014 | Panasonic Panafax Uf-8000 uf8000
My machine drops stitches, bobin hangs up, thread knots up. I have cleaned the bobin case and feeder. What can I do to fix the problem?
This may sound very simple, but try putting in a new needle. If the needle is blunt or has a burr on it, that could be the cause of your issues.
If it is a drop in bobbin style machine you may also have a "needle nick" on the plastic bobbin case. The thread can get caught up on those little knicks causeing it to get caught up or fray.
You can pollish down the little knicks with a very fine sandpaper to smooth them out.
Apr 21, 2011 | Elna 2007 Mechanical Sewing Machine
Panafax UF-8000 not responding, energy saver light flashing.
It sounds like the operation panel is bad or has a loose plug.
Remove left and right top screws that hold the left and right panels on.
Wiggle the op panel towards you and up, check the white wire harness.
Good Luck!
Jul 07, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Email problems on Panafax UF-8000
you need a IFAX/email key "small little electronic board" installed on the main board it does not come as default so you need to talk to your dealer about this option
Nov 20, 2008 | Panasonic PanaFax UF-8000 Laser Fax
J 72
I don't have my manuals today, but I think there's a jam in the ADF (just pull it straight up to open)
Sep 05, 2008 | Panasonic PanaFax UF-8000 Laser Fax
How do I scan a bunch of originals from the tray and get 1 file for each page?
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
May 13, 2008 | HP LaserJet 3030 All-In-One Printer
Panasonic PanaFax UF-8000 Laser Fax Logo
57 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
