Question about Philips Magnavox 27MS343S 27" TV
Magnavox tr3272C103 black covering the center of screen, Outer portion of picture viable including audio, Has 8 number and letter in brackets next to 3 number in brackets in uooer left portion of the black portion of screen? Thank you
  • 252 Answers
Maybe the close caption has turn on.,by using your remote press the menu and find the close caption and turn it off .
Posted on Oct 08, 2008
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
Where can I find a service manual? I need to change the 3 wire power cord to a 4 wire cord.
first install the RED & BLACK conductors on the cord to the L1 & L2 terminals or the 2 outer terminals on the 3 position terminal strip on the dryer,next take the WHITE ( NEUTRAL) wire on the cord connect it to the "N" terminal on the dryer terminal strip usually located between the 2 phase wires RED & BLACK so the terminal strip will be(RED-WHITE-BLACK) red & black can go on either outer terminal as they are not polarity sensitive due to the A.C. current, then the GREEN on the power cord goes to any metallic portion on the dryer case
Aug 23, 2012 | Maytag ADE7005AYW Dryer
The TV has a full picture with sound for approx 30 seconds then a large black square appears in the center (covering 90%) of the screen. The program sound continues to work and the remaining picture can be...
whats the model number of the tv? What happens if you press the menu option either on the remote or tv? if its LCD -Without opening the tv and t-shooting it sounds like either the tcon or audio video board.
Apr 05, 2011 | Televison & Video
How to install new lcd screen
Installing a new LCD is fairly easy in this model.
#1 Remove two bottom screws
#2 Remove four side screws
#3 Slide off silver side panel on the left Front side of the camera
#4 Carefully remove front cover (careful to pry off from the top)
#5 Flip over front cover and release the power panels ribbon cable from the system board
#6 Flip over plastic protector
#7 Remove Back Cover from LCD side
#8 The LCD is being held by 3 ribbon cables.
(This next step should be done very carefully - damage can occur if it is done incorrectly)
#9 Release the middle ribbon cable by carefully flipping up the black portion of the clamp.
Equal pressure should be applied to the full black portion when attempting to flip open.
Do not use excessive force.
#10 Release remaining cables and remove LCD.
To assemble just reverse the steps. We have color diagrams available just ask.
Thank you
Jan 24, 2011 | Sony DSC-T70 Digital Camera
Need another set of tv-to-tv cables. An a/v cable and a dc cable
I had to move my AV cable around quite a bit to get the second monitor to come on. I realized it was the cable and not the connection by holding steady the connections and moving just the wire. I checked Radio Shack and Best Buy - no luck...
Then I did the following (takes 30 minutes max):
1.) found the portion of the cable that was bad
2.) carefully sliced open the outer jacket (with a box cutter razor),
3.) carefully pulled the wires (white, red, yellow, and bare copper ground) out of the outer black jacket. Inspected and found no visible defects. Realized that likely the yellow wire (probably the video feed) was shorting against the bare did the following remaining steps to remove the ground away from other wires.
4.) cut and unwound the ground,
5.) put the white, red, and yelllow wires back inside the outer black jacket, but left the bare ground out
6.) wrapped the two ends of the bare ground (that I cut in step 4) around the outer black jacket (still containing the other wires)
7.) reconnected the two ends of the bare ground, by twisting them together (you'll use-up an inch or two of the ground to re-twist it, so you will have to leave a small bump in the cable from the excess black jacketed portion.
8.) use black electrical tape to wrap all the wires together from the portion we opened-up.
Works like a champ.
Jul 06, 2010 | TruTech LMD-5702RT Portable DVD Player
Need to remove the outer cover on a Gateway
If you get power to the controls and you don’t have the startup sound or see the gateway logo when you plug it in, the main board may be bad.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
If you have the startup sound and see the gateway logo and the screen just flashes and the power buttons stay lit, then it sounds like probably the inverter may have went.
Take the screws out of the bottom rear edge (these hold the front trim), and the 4 big black ones at the middle of the back that hold the stand bracket.
The trim then unsnaps. {Be aware of the small ribbon to the power button board on the right edge}Start at the bottom and release the trim (pulling up the trim on the screen side usually starts it off), then work your way up each side bottom to top ((a pocket knife or thin putty knife even a credit card, will help release the catches as you work your way up)
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the ribbon at the power button board, (Tiny latch lifts up on a hinge and ribbon slides out)
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift out with all the guts. You may have to pry up on a corner with a screw driver to get it started.
The inverter is under the medium size metal case.
The power board and main board are under the large cover.
You’ll then have to remove a bunch of screws including the usb board ones and unplug the bulbs and wire to the screen
then the power board and control board is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the board , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
Oct 09, 2009 | Gateway FPD2485W Television
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Need video jack
I interfaced the SAVV LM-S6001 today. Here's what I found;
Looking straight on at the male 8 pin DIN connector here's how I'll describe it. There are 3 pins across the top row. From left to right I'll call them 8, 7, 6. There are 2 pins on the left side of the middle row, 5 leftmost and 4 adjacent to the center. Moving right, there is a gap and then pin 3 on the rightmost side of the middle row. There are two pins on the bottom row, pin 2 on left and pin 1 on right. Draw that on some paper.
8 7 6
o o o
5 o o o 3
o o
2 1
Pin 1 is +12VDC
Pin 2 is center contact of both audio and video RCA jacks
Pin 3 is -12VDC
Pin 4 is outer RCA contact for Video
Pin 5 -n/c
Pin 6 -n/c
Pin 7 -n/c
Pin 8 is outer RCA contact for Audio
Now, I don't know what pin 7 does, but it is wired next to pin 4 suggesting a video application, Svideo is my best guess. I can only test for a composite video connection that I am using.
It's alive!
Jul 09, 2008 | Savv LM-S6001 Car Monitor
Mitsubishi WS-65315
Could this be CC or Closed Caption set on Text? Try turning off
Jan 26, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Philips Magnavox 27MS343S 27" TV Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
