Question about Philips Televison & Video
Pink (Magenta)vertical line appears on the screen
A pink (Magenta) vertical line appears on the screen from time to time about 2/3rds from the left. I am able to get rid of this line by switching the set off for about 20 secs. This may happen 2 or 3 times in one night and then may not happen again for another 2 weeks or so.
    President:
  • 2,712 Answers
Vertical magenta lines could be a symptom of a loose connection to the optical assembly,or a source of interference. Try resetting the TV first - unplug from wall socket for about 2 hours, replug, and see if it works.
Also check the cables/connections from your cable box, etc and see if the issue can be resolved by manipulating the wires. Could be a loose connection..
Posted on Oct 03, 2008
PINK LINES ON THE LEFT HAND SIDE WHEN PRINTED
How old are the pcr units (drums). sounds like either a problem with the magenta drum or the magenta toner cartridge is leaking.
Sep 18, 2014 | Lexmark C530dn Laser Printer
LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
Jul 22, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
2 Vertical lines on screen
It's either one of these things is dying:
Your Screen, or
Your video card
You can find out which by hooking your computer up to an external monitor, and if the lines appear on it, then it's your video card. If not, then it's your screen dying. And so you can either get a new screen, or a new computer.
Oct 02, 2009 | Compaq Presario M2000 Notebook
Pink vertical line
To start try reinstalling display adapter drivers. Try also to start from a boot disk or to install a different operative system.
If it does not go, and does not depend on the system, a static vertical lines is either faulty display adapter or faulty LCD display. Usually the video adapter.
Jul 20, 2009 | Compaq Presario M2000 Notebook
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
Televison & Video Logo
698 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
