Question about Medion md40298 Notebook
Meridon 95000 The inlet port /socket has become dislodged and loose is only works by taping in the male connector ,and is'nt going to last much longer in this condition Is there anyone who can carry out this repair economically Thanks Karl
  • Anonymous Dec 06, 2008
    I have exactly the same problem with my medion laptop except for taping no longer works either.
    I think its going to have to be sent off to medion for repairs.
Male power port is loose
the power socket on the back of the pc also known as a male IEC socket can easily be replaced but should only be done by qualified technicians like myself we are talking about mains power it kills people, but the preferred option is simply to replace the power supply unit in the computer
Oct 01, 2015 | Computers & Internet
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Jul 16, 2011 | Computers & Internet
Trying to figure out how to connect VCR to laptop ie cables etc Want to transfer tapes to DVD
This will depend on what the connections are on the laptop. All you need is a video in and two audio (left & right) in connectors. If these are 3.5mm jacks sockets on the laptop. Then all you need is convertor cables. It will be easy if the VCR has a scart socket. As you can get a scart plug that has RCA plugs on the other end for audio and video out. All you need then is 3.5mm to female RCA plug lead(s) or if you can only get them with male RCA plugs, 3 inline connectors.
You can also get a USB to RCA plugs. See image below.
images below as well: of 3.5mm cable with RCA (male) and the female version and couplers for the males, plus the scart lead (yellow RCA is video) (all cables can be get from Amazon)
Jun 04, 2010 | Emerson Televison & Video
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page:
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable:
hope this can help you
Feb 04, 2010 | Sony VAIO FW Series VGNFW275JH
We have Dell OptiplexGX745 smallform factor desktop computers that we need to run two monitors.
If your Dell Optiplex GX745 came with the ATI Radeon X1300 graphics card, that has One - DVI graphics port, and One - VGA graphics port, it's no problem.
This link shows an ATI Radeon X1300, and the two above mentioned graphics ports,
(Please scroll down to the larger photos for more detail.
The Radeon X1300 graphics card in your computer, is a Low Profile graphics card. It will not look exactly like the one shown.
Low Profile means shorter in height. Your graphics card is shorter in height, in order to fit in your SFF computer case. {Small Form Factor}
The longer white connector shown on the left side of the view, is a DVI port. (Technically it's a Dual DVI port)
The shorter blue connector shown on the right side of the view, is the VGA port.
1) If one of your monitors has a DVI connector plug, simply plug it into the DVI port.
If the other monitor also has a DVI connector plug, you will need an adapter to plug it into the VGA port.
2) If both of your monitors have a VGA connector plug, one will plug into the VGA port on the graphics card.
The other will need an adapter to plug into the DVI port, on the graphics card.
This link shows an adapter for connecting a monitor with a DVI connector, to the VGA port on a graphics card,
The adapter to connect a monitor with a VGA connector, to a DVI port on the graphics card is opposite of this.
[ I have found them at Radio Shack.
This = Expensive! $14.99
Not advertising for Radio Shack, or the above website in the link]
Use care when selecting the adapter you need.
A monitor with a VGA cable connector has the Male pins.
Your adapter must have the VGA Female sockets.
The DVI side of the adapter must have the Male pins.
It goes into the Female socket holes on the graphics card.
Same with a monitor that has a DVI cable connector.
The adapter must have Female DVI socket holes.
The other side will have Male VGA pins.
If your ATI Radeon X1300 only has One - graphics port, I Do Not advise using a splitter.
This is an adapter cable that has a connector on one end, and splits into two cables.
The graphics quality will be poor.
If you have No graphics card the situation is worse. This is Onboard, or Integrated Graphics.
(OnBoard. On the motherboard)
Using a splitter cable will result in very poor graphics.
How to tell if your Optiplex GX745 only has Integrated Graphics?
Look at the back of the computer. Come down from the audio ports. (Green and Blue)
Look under the USB ports.
The Blue VGA port is the Integrated Graphics port.
If you have an ATI Radeon X1300 graphics card, you will see a blue VGA port in an adjacent slot, also.
(Your computer can have Integrated Graphics, and a graphics card.
You CANNOT use the Integrated Graphics port, and a graphics port on a graphics card, At The Same Time!
It will Not work)
Once the two monitors are attached.
1) Turn both monitors on.
2) Turn the computer on, let Windows load
3) After Windows has loaded, Right-click on any empty area of the desktop screen.
4) Go to the bottom of the drop down menu, and Left-click on Properties
5) There are tabs across the top. Left-click on the
Settings tab.
6) You will see two rectangular icons. These icons represent monitors.
The one on the left side with the white border around it, is your Primary monitor. The main monitor you have always had.
The grayed out icon on the right side represents a Secondary monitor. This is for the second monitor you plugged in.
Note how the two monitor icons are sitting.
Primary on the left, Secondary on the right.
This is how your monitors should be sitting.
If it is Not, left-click on the Secondary monitor icon. Hold the left mouse button down, and drag it over to the left.
Now scroll down this window with your eyes.
Under the resolution settings you will see -
Extend my Windows desktop onto this monitor
There is a square box to the left of it.
Left-click in the square box. Go below to the right, and left-click on Apply.
Now go to the left, and click on OK.
Your monitors will now both be showing your desktop screen.
[Note* When doing this procedure, you have clicked on the Secondary monitor icon. Clicking on the icon activates it]
When you open the internet, or have a program going.
Go to the right side of the screen to the blue border,
of the Primary monitor.
When the mouse cursor turns into a double-headed arrow, hold the left mouse button down, and drag the screen to the right.
(You will note that the mouse cursor changes quite easily. It has to be double-headed in order for this to work)
If this direction does not work, go to the left side of the screen, drag to the left.
(You have to drag in the direction your monitors are actually sitting, in relation to each other)
Need some clarification, or have further questions? Click on Comment.
Jan 14, 2010 | Intel computers9: P3 Computer Computer...
Brake Lights do not come on. The connector located at the top back of the brake pedal becomes disengaged very often. One has to, upside down on you back, push the male and female parts back together. This...
i am assuming the lights work while connection is engaged. simple secure the two parts of the connection together even if you have to with gaffer tape.
Nov 24, 2009 | 2004 Ford F250
Cigarette Lighter Pulled Out
there could be a wire in side the unit its self and that might have come dislodged
try it and let me know
Feb 28, 2009 | 1999 Toyota RAV4
Won't heat
I have the same smoker with the same problem. I checked the heat element with an ohm meter, it was good so just cleaned the burnt residue from the male spade connectors attached to the element with a dremel tool. Slipped two new female spade connectors over the ones on the element and soldered them with the wires attached with a 1/16' silver bearing electronics solder. Now the connections cannot become loose and burn up again. I tested everything out and then wrapped the exposed connectores with non conductive fiberglass electrical tape and covered everything with expanding foam that comes in a spray can. Easy fix for me after reading all the posts from you guys here. Good luck and go for it! All I had to buy was the foam insulation.
Corpus Christi TX
Jul 13, 2008 | Masterbuilt ESQ30B Smoker
Male moniter plug on both moniters(every one in the world) and motherboard
That Male connector is a serial port not video, you need to get a video card and plug the monitor to this card.
thanks for rating
Jan 10, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Medion md40298 Notebook Logo
109 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
