Question about Toshiba Satellite M50 Notebook
Toshiba Laptop Malfunction (2)
I have a toshiba Equium M50-216. When you login, the desktop fires up and it looks like it is working. However, it then switches itself off and restarts. It will constantly do this cycle until the battery is removed to turn it off. I can't even use the recovery disc because once the desktop appears , it just restarts again. Please can you help. (i have music and pictures i don't want to lose). Thank you.
    Genius:
  • 1,124 Answers
This problem could be caused by some hardware or software conflict or power supply.
Do the following:
When your computer start and before windows load hit F8 and select "safe mode"
On safe mode unistall the last program installed (if you've installed any) and also all innecesary programs installed on your machine. Run some registry cleaner.
Start in normal mode and see what happen.
Posted on Oct 03, 2008
    Novelist:
  • 124 Answers
Hi manny, have you tried booting to safe mode? (when you see the toshiba logo, press F8 continously until you see the Advanced Boot Options, choose Safe mode or Enable VGA Mode then check if the problem still persist. If it doesn't, it's a possible video driver problem, maybe windows update changed it if you set windows automatically to download & install drivers for your computer. If that doesn't fix it, maybe one of your startup programs might be causing it, try running msconfig (start > run > msconfig) then disable all startup items on the startup tab & also on the services tab also (check "hide all microsoft service" first before clicking on disable all). Give me a feedback
Hope this helps.
2 Suggested Answers
Ray-Tosh
  • 124 Answers
SOURCE: Toshiba Laptop Malfunction (2)
This sounds like 2 things, it could be a video driver conflict or there's a startup program that might be causing the problem. To check which is which, try restarting the computer > press F8 when you see the toshiba screen until you get the Advanced Boot Options.. then choose Enable VGA Mode (I'm assuming your using WindowsXP). If that works and you get to the desktop screen with no problems, try removing the display driver & replace it with a compatible one (usually on the cd that came with the laptop). If that doesn't work, try choosing Safe Mode and run msconfig (start > run > msconfig) and disable all services & startup programs (don't forget to check "hide all microsoft services"). then restart the computer. If this doesn't work and continually goes to a loop, do you see a bluescreen with error messages on it? Like Error 0x00000003 or 0x0000000E etc.? or a memory dump error? That could be a hardware problem already and it may require service.
Hope this helps.
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
I am looking to reformat the hard drive (ie restore to factory settings) of a toshiba equium a60 laptop. However, I have no manufacturer disks so wondering if it is possible?
I've had a look at the the Toshiba website:-
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Toshiba+Equium+7100S+&x=9&y=8
It gives the impression that this is quite an old system. That being the case, re-installing windows requires re-formatting the HDD.
But keep the URL above handy, it may help with drivers you may need after the re-installationt.
Apr 29, 2010 | Toshiba Equium 7100S PC Desktop
My Toshiba Equium laptop will not read CDs or DVDs
Is CD/DVD showing in my computer?
Are you reading retail or homemade CDs?
Use retail to test reader, any will do.
Not all homemades work in all readers.
Look here:
http://repair.laptopsinfo.net/How_to_open_toshiba_equium_laptop
Apr 04, 2010 | Toshiba Equium 100 PC Desktop
My toshiba equium A110-233 malfunction
try removing the battery and power adapter for a few minutes then plug in just the power adapter and boot up. then shut all down and put in battery and adapter and see if that helps.
Jan 02, 2010 | Toshiba Computers & Internet
Toshiba satellite laptop doesn't work after ipod removal
format and install a new operating system..start fresh
Apr 04, 2009 | Toshiba Equium 100 PC Desktop
Laptop equium l10
Hi, My Name is Henry. I am one of the technicians here.
You need to upgrade your bios. Go to the http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
click download and follow the instructions.
NOTE THAT YOU HAVE TO BE VERY CAREFUL WHEN UPDATING THE BIOS BECAUSE YOU COMPUTER MAY DEVELOP MORE PROBLEMS IF YOU DO IT WRONGLY.
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Mar 17, 2009 | Toshiba Equium 7100S PC Desktop
Toshiba Equium Laptop keyboard not operating correctly
There has been a lot of talk around this computer lately about the same problem you are having. It has something to do with the plug that plugs into the mother board it self.
Feb 05, 2009 | Toshiba Equium 7100S PC Desktop
Hope this helps.
Oct 03, 2008 | Toshiba Satellite M45-S265 Notebook
My loptop doesnt start-toshiba equium a100-306
Try reinstall the OS. or press F5 or F8 when boots AND LOGIN TO SAFEMODE AND DO SYSTEM RESTORE. if are not able to go to safemode, then press del when boots and getinto the bios and check the bootable device is harddisk
Nov 13, 2007 | Toshiba Equium 7100S PC Desktop
Toshiba Satellite M50 Notebook Logo
143 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
