Question about Sony Ericsson K750i Cellular Phone
JOYSTICK STRUCK sometime joystick i.e (scroll key) strucks cannot able to move the options up or down&left or right
Buy new one!!
Posted on Oct 07, 2008
THE BATTERY LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT AND CHAIR WILL NOT MOVE
Turn on Joystick and push horn twice, you are in locked mode. If this didn't work then turn Joystick on push gimbal forward until you hear a beep, then move the gimbal back until it beeps you are now unlocked. Gimbal= what you push to go left right forward or back on a joystick.
Jan 27, 2016 | Pride Jazzy Select Elite
Tip
Resetting the Lamp Timer
After replacing the lamp, you need to reset the lamp use timer. The manual is a bit cryptic on how this is done. The manual says "Fn. Up > Fn. Dn. > Vol. Dn > Vol. Up > Enter > Power" However, my remote has no "Fn" or "Vol." controls. Further study of the manual shows that "Fn. Up" = joystick up; "Fn. Dn" = joystick down; "Vol. Dn" = joystick left; "Vol. Up" = joystick right; "Enter" and "Power" are keys on the Remote, "Enter being "6 o'clock" position on the ring encircling the "joystick" I am calling the control that one would use to move the cursor on the screen the "joystick" Thus to reset the timer, key in from the remote "cursor up" "cursor down" "cursor left" "cursor right" "enter" "power"
on Sep 12, 2008 | LG RD-JT30 Multimedia Projector
The right joystick on my 360 controller wont give me full range of motion even though the stick moves prfectly fine
Well, it may be because the XBOX has a de-sync, making the controller delayed when you give it orders.
I suggest using another controller. If that doesn't work, contact Microsoft support.
Nov 27, 2017 | Microsoft Xbox 360 Controller
How do you set the correct time ???
Press and hold the source button until the unit turns off. Then with the power off, press and hold the multi-function control (i always call this a joystick since you can move it left, right, up or down OR press it like a button and it reminds me of old video game controllers). When you press the joystick for a moment it will bring up an initial settings menu. Scroll to the clock option and press the joystick button to enter. Use left and right to select minutes and hours and use up and down to change to the correct time and you're done. Press source again to turn the unit back on and you should be good to go. Enjoy!
Dec 01, 2010 | Pioneer DEH-P5900IB CD Player
MASTER RESET CODES FOR SONY ERICSSON
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
My sony ericsson k750i joystick is broken.
Your joystick might have accumulated a lot of dust inside it. Try to clean it with alcohol or blow it off with some high high pressure air.
Jan 30, 2009 | Sony Ericsson K750i Cellular Phone
Toshiba Tecra: How to turn of directional buttons
I'll bet it's the mouse in the keyboard that is at fault rather than your left arrow. Try pressing the little joystick mouse device in between the G and H key and above the B key to the right when your pointer drifts to the left. If it's the joystick moving it and then letting it rest should re calibrate it.
Let us know whether or not the joystick is the culprit or not so we may continue to help you?
Sep 06, 2008 | Computers & Internet
I don't think you can turn them off.
Check the mouse in the keyboard it could be at fault rather than your left arrow key/switch. Try pressing the little joystick mouse device in between the G and H key and above the B key to the right when your pointer drifts to the left. If it's the keyboard's joystick then moving it a little and then letting it rest should re calibrate it.
Let us know whether or not the keyboards joystick is the culprit or not so we may continue to help you?
Joystick
It is rather frequent problem with Nokia.
If your mobile warranty is expired then try to disassemble your phone and clear you joystick of dirt.
If it doesn't help then nothing can be done but bringing it to service.
As far as I remember menus on 6600 are not recurring so you can not use only up direction to reach icons that are below. I did so on E70 when had he same problem with joystick.
Jun 29, 2008 | Nokia 6600
How do i get rid of replace lamp message & reset lamp timer
If you are using the RM-PJ2 remote control, following these instructions. You will have 5 seconds to complete the key sequence.
1. Make sure the Projector is in "Standby" mode. There will be a red light instead of green
2. Press the Reset button
3. On the "joystick" type button, toggle the left directional arrow
4. On the "joystick" type button, toggle the right directional arrow
5. Press down on the "joystick" button to press Enter.
6. Your lamp hours should now be reset.
Recap: Reset, left arrow, right arrow, Enter, all within 5 seconds.
Mar 26, 2008 | Sony VPL-EX1 Multimedia Projector
Sony Ericsson K750i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
