Question about Canon Office Equipment & Supplies
Canon imagePROGRAF W8400G Bought used machine. Saw it running prior to moving to my premises. Since installing it I have not been able to print. Keep getting error message 'check printhead'. Have run through both cleaning cycles. Have removed and put back in the printhead. Nozzle Check print runs fine, as does test print. However, still cannot achieve a print from laptop. Cannot afford to spend £400 on a new head unless absolutely necessary. Any other ideas before I flex the plastic ?
  • sav_8604 Dec 09, 2008
    Hi , I have same problem but not sure how to take out the head as it moves into far right hand side where I can't even touch it?
  • 121 Answers
SOURCE: Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
You'll probably need to replace the whole printhead.  It's a bit of a job on that machine
Posted on Oct 27, 2007
JongCur
  • 88 Answers
SOURCE: i860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Posted on Apr 09, 2008
  • 54 Answers
SOURCE: Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
Posted on Apr 09, 2009
komguy
  • 2306 Answers
SOURCE: We keep getting an error message
Yes, you need a new printhead, QY60061-000
around $40.00
Posted on Jul 01, 2009
  • 15 Answers
SOURCE: HP L7680 print head problem
When installing the print heads out of the box you MUST shake them for 30-60 seconds, same goes for ink tanks. If you do not then the lubricant that is added to them will seperate and it will draw thinned out ink causing damage to the print heads. Also, if your system sits for more than a couple weeks (and this goes for ALL printers) then run a test page ence every 2 weeks to keep the system from drying out.
I used to work at a couple office supply stores and this was almost always the issue with bad printheads on HP, Brother and Cannon printers.
Posted on Aug 31, 2009
How to update canon ipf605 firmware through download mode
To enter DOWNLOAD MODE the machine has to be switched OFF. While the machine is off, hold down the stop button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in DOWNLOAD MODE.
then later you can use L printer services tools to update or go to canon website select support & download select you model machine and windows OS find firmware update tools .after install it he will automatic detect you printer then he will go internet online download the new firmware install it.
please never do any printing when upgrading firmware. After finish it will automatic restart machine.
Nov 17, 2016 | Canon imagePROGRAF IPF605 Printer
Canon ipf 8000s
Over heat of the print head.
Turn off - Turn on the machine, if this will not work try to access the service mode update to the latest firmware version and replace the print head
Dec 25, 2009 | Canon imagePROGRAF iPF8000 Printer
How do i disable the ink moniter on a ipf600 wide format printer
Initiate, preview & monitor jobs easily ... The Canon imagePROGRAF iPF600 24-inch large format printer produces stunning, color, ... The imagePROGRAF iPF610 features a Reactive Ink system consisting of four highly colorfast dye inks - Cyan .... The affordable solution for wide format copying, printing and scanning. ...
www.copiersplusinc.com/used.html
Dec 06, 2009 | Canon imagePROGRAF IPF600 - large-format...
Canon ipf700 error 03130031-2f13.
if after the code you had to shutter down, and then the plotter made a head cleaning, we fix just putting a little of oil in the band, in the section were the head print moves.
Nov 16, 2009 | Canon imagePROGRAF IPF710 Printer
Change print head on canon ipf610
I have a iPF600 and need to reinstall printhead. How do you get the printhead to move to the middle so you can take it out?
Nov 04, 2009 | Canon imagePROGRAF iPF610 - large-format -...
No power
hi this is kamal
pls call to any printer vendor or yourself clean the dust and install printer driver and correct your printer settings...
then let me know
bye
Oct 08, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Canon prograf w8400
GO ONLINE AND TYPE THE FOLLOWING:
CANON IMAGEPROGRAF W8400 INKJET PRINTING 2 INCH BLACK LINE
ENTER
SEE IF ANYONE ELSE HAVING THIS PROBLEM BEFORE, GET SOME HELP OR IDEAS ON HOW TO FIX IT
GO ON LINE TO
WWW.CANONUSA.COM/IMAGEPROGRAF
ENTER
ROD
Feb 10, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Canon imagePROGRAF W7250
I did not see that there was a response on Apple's support site that adds to the previous post I mentioned. Combing the steps from the two posts, I was able to get our W7250 to print from Mac OS X 10.5 Leopard.
Here are the steps I took to get a networked Canon imagePROGRAF 7250 to work with a Mac running Leopard :
1. Download garo34 print driver from Canon's support site here.
2. Download the iPF610/iP710 Leopard print driver from Canon here.
3. Double-click on the garo34_osx.hqx file that you downloaded.
4. A folder named Driver is created; open it and double click on "GARO Installer for X".
5. Enter a name and password of an administrator account on your Mac and click OK.
6. When the GARO Installer for X window appears, click on Continue.
7. Click Continue.
8. Click Continue.
9. Click Agree.
10. Click Install.
11. When the installation is complete, click on the Restart button.
12. When your system has restarted, double-click on the iPF610_710_Driver_OSX_10.5_Ver1.10.hqx file you downloaded.
13. A folder named iPF610_710_Driver_OSX_10.5_Ver1.10 is created; open it and double-click on "iPF Driver Installer X".
14. Enter a name and password of an administrator account on your Mac and click OK.
15. When the iPF Installer X window appears, click on Continue.
16. Click Agree.
17. Click Install.
18. When the installation is complete, click on the Restart button.
19. When your system has restarted, click on the System Preferences icon on your Dock or select System Preferences from the Apple pull-down menu.
20. When the System Preferences window appears, click on the Print & Fax icon.
21. Click on the + Button underneath the Printers column.
22. Another window will appear; click on the "More Printers" icon.
23. A drop-down window appears; select Canon IP (GARO) from the pull-down menu if not already selected.
24. In the "Printer's Address:" field, enter the IP address of your Canon W7250 printer (e.g. 192.168.1.2).
25.In the "Queue Name:" field, enter a name for your printer (e.g. W7250).
26. Click on Add.
27. The W7250 is now your default printer. If you want another printer to be the default, change it in the Print & Fax preference pane.
Voila!
I hope this solves your problem and you found the instructions helful.
Mark
Jan 09, 2009 | Canon imagePROGRAF W7250 InkJet Printer
Canon I560s printer
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Jul 03, 2008 | Canon BubbleJet i560 InkJet Printer
you need to enter a service mode before the error message pops up. hold down paper source button + online.
that should override the message before it pops up.
go to replace print head selection. or do a clean. it may still be working. let me know if this doesn't work....but at least you can still get past the message now! marty
Oct 27, 2007 | Canon imagePROGRAF W8200 InkJet Printer
old marine
old marine
