Screen goes black for a minute or two and then comes back. Could it just be the bulb? The replace bulb light is not on.
It is possible but the only way to know is to try that.
Lamps have about a 2000 hour life span which works out to about 2 years for the average user.
Usually in this model just before the lamp fails the picture either comes on somewhat darker than usual or gets dark just before the picture goes out.
The set will detect lamp is not bright enough etc and blank the screen.
The lamp light (I have seen this) sometimes will not come on even if the lamp has a total failure----no picture at all.
You might also check with a local shop or someone with the same model so you can swap lamps to see what the problem is.
Let me know what happens.
