Question about HP Laserjet M1319F Laser Multifunction Printer
FAX TRANSMISSION I LIVE WITHIN AREA CODE 514, MY FAX WILL NOT SEND TO AREA CODE 418. THE FAX AT THE OTHER END RINGS AND THERE ARE FAX TYPE NOISES BUT AFTER THIRTY SECONDS OR SO THE DISPLAY INDICATES "NO FAX DETECTED". I HAVE TRIED SEVERAL FAX NUMBERS IN THIS AREA CODE WITH THE SAME RESULT. THE PEOPLE TO WHOM I AM SENDING CONFIRM THAT THEIR FAX MACHINE IS RINGING.
  • Anonymous Oct 22, 2008
    I have the same problem. I can fax perfectly to some while others ring, but my fax states no fax detected. I know it is this machine because I can fax with my other machine to the same number perfectly. If anybody finds a fix for this, please email me at mrp@uskmfg.com. Thank you so much!
  • Anonymous Dec 05, 2008
    I have the same error. When I send oversea fax, it shown "No fax detected" or just "Busy", however, if I send with other model such as 3050 or 1152, it went through straignt without any error. HP local vendor called but could not help.
I have had this issue as well faxing to any area code in general outside of my own. The only thing I found to work was manual faxing. This comes from the manual.
Dial manually from the handset
1. Load the document into the ADF.
2. Call the recipient on the handset.
3. When the recipient is ready(when you hear the fax sound), press Start Fax on the product control panel.
Posted on Nov 04, 2008
I have user with same issue. She got on the line with HP. Manual settings had to be changed on the machine. All she could say was that had to go to Setup, then something about commercial ring off and some other stuff. Fast talking with a little computer literacy. Couldn't get alot from the conversation
Posted on Dec 29, 2008
  • 661 Answers
It is possible that there are "gain" issues on the telecoms link line from 514 to 418... I'm not sure how this is best resolved....apart from speaking to your telecoms company, try to find out which telecoms company these recipients use to see if there is any common provider with this issue, however any resolution along these lines is unlikely to be resolved quickly.
it may be best to perform a "scan to email" if your machine supports it, where a fax machine/scanner scans the sheets and then attaches the scanned images to an email on your PC, which you can then sent to an email recipient. the recipient can then print and treat like received fax...
as your fax machine appears to send ok to recipients in your own area code, I can only assume that it is working properly.
Posted on Oct 03, 2008
We recently switched our phone line carrier to Comcast. Since then, some of customers (but not all) cannot send faxes to us or receive faxes from us. Specifically, we can't communicate with ANY customer in...
Start with COMCAST. They are your service provider, and if everything was working well before you switched then they need to make it right. Since you are using the word customer, this means that the service disruption is affecting your business. Call customer support now.
Mar 18, 2015 | Canon FAXPHONE L170 Laser Fax - 0815B002AB
My fax will not send. the report says fax sent and the result is no answer
Sounds rather conflicted...any way, first step "send" a fax to a phone that rings (cell phone, phone near the fax). Make sure that the phone you are calling rings, if not plug a phone in to the fax line and make sure you have a dial tone. If you do try to change the phone line on the fax and repeat. Basicly this step is to ensure the fax is dialing out.
Next, dial the number you are faxing to with your cell phone or another phone. Does the fax machine at the other end answer (squaking noises). If not are you dialing the right number. If the fax machine at the other end does pick up, hang up and wait a few mins (so the line will clear) and try to send your fax again.
Try sending a test fax to a known good (have sent faxes to the number before with success) fax. If this works, its a communication hand shake error. You may need to power cycle both fax machines.
Last Test, plug a different fax machine in were this one is. Using the same phone line and such try to fax again. If this is the only thing that works, the fax machine may have a bad modem.
If further information on testing the modem on the HP fax is needed let me know.
I hope one of these step gives you the help and information you are looking for.
Jul 22, 2011 | HP PSC 950 All-In-One InkJet Printer
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
HP Officejet 6310 All-In-One InkJet Printer Changed home telephone system and now I can send faxes out but cannot receive?
Hi
Check the following link
CAN SEND but CANNOT Receive
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button () on the product control panel.
    2. Press 4 for Basic Fax Setup, and then press 1 for Fax Header.
    3. Type personal or company information using the keypad, and then press OK.
    4. Type the phone number, including area code, for your HP fax product, and then press OK.
  2. Dial 1-888-HPFaxme and send a fax to the HP Fax Test Service.
Jan 04, 2010 | HP Officejet 6310 All-In-One InkJet...
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Poor Line Connection
If the fax works in all other instances other than when you dial a certain area code I would say the problem is definately not associated with the machine itself. I have never heard of this type of problem. I would contact your phone company and tell them your situation and see if they have any advice from their end.
Feb 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Will not send outgoing fax
From what your saying, the problem is not on your end, but on the receiving end. The other fax is not answering the call.
Nov 27, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP Laserjet M1319F Laser Multifunction Printer Logo
309 people viewed this question
Seeker5211
Seeker5211
