Question about Magic Chef MCWC30MCG Compact Wine Cooler
Temperature setting doen not work - Magic Chef MCWC30MCG Compact Wine Cooler
  • Anonymous Oct 07, 2008
    I have the Magic chef wine cooler and it is not cooling. I unplugged it when the temp was reading 78 degrees!!! It was cooler to unplug it!! Does anyone know where you can get this repaired?
  • 750 Answers
Welcome to Fixya.
You said, you have the Magic chef wine cooler and it is not cooling. I unplugged it when the temp was reading 78 degrees!!! It was cooler to unplug it!! Does anyone know where you can get this repaired?
here in our fixya site there are serviceres from all round the country.
click on Browse the Repair Directory an you may find a serviser in your area.
let me know you found some one!
Please remember to leave me a rating before you leave me!
Posted on Oct 08, 2008
The thermostat at less than number one on dial and everything freezes,is it the thermostat.MCWC30 MCG Magic Cheif wine cooler
Posted on Oct 14, 2009
My temp. gauge will not move.
Either it doens't work or your temperature sensor is bad. I would guess that your sensor is bad.
Dec 31, 2011 | 1994 Mercury Tracer
Can't set temperature
first go turn breakers off at indoor unit or if gas turn switch or unplug for thirty seconds.should be a hold button on thermostat , set desired temperature and press hold allow five minutes to go by.listen doen anything at all happen at unit.
if nothing happens after five minutes remove sub-base from wall and at the thermostat jump with a wire the r terminal and the white terminal see if it comes on if so you got a bad thermostat most likely.
Dec 02, 2011 | Honeywell Programmable Thermostat Heater
97 chevy lumina are there coolant fan sensors
This year doen't use a separate sensor for the cooling fans, it uses the ECT (engine coolant temp sensor) sensor that monitors engine temperature for the fuel control system, the computer turns the fans (via a relay) on when the engine reaches about 225-230 Degrees F
Oct 11, 2011 | 1997 Chevrolet Lumina
Dazzle dvc 120 doen't work with windows 7
Problem with the Pinnacle Dazzle DVC 120 Video Capture dazzle dvc 120 doen't work with windows 7
Aug 11, 2011 | Pinnacle Dazzle DVC 120 (210100394) Video...
Cooling issues (low refridgerant?)
Make sure both the evaporator and condensor coils are clean. After the unit has been off for a couple of hours, start it back up and measure the temperature difference between the air entering into the unit (room air temperature) and the air blowing out of the unit and into your room. You should have approx 20 deg......take this measurement after approx 5 minutes of run time. If the temperature difference less than 15, you may very well have a refrigeration problem. If it is approx 20 degrees, then it could be a dirty coil or an electrical problem.......inspect all of your electrical wires and controls for any signs of overheating.....tighten all connections.
I hope you find this to be very helpful in your diagnosis. :-)
Mar 23, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Heating problem
I came across this due to I was searching for a transmission issue and saw this. But I had the EXACT same issue just this past September. The blower worked, on all vent settings, but when the temperature setting was adjusted, to any heat level, with exception of it being at the coldest temp setting, I had nothing but cold air blowing out with the continous clicking noise. There was no heat from any of the vent settings. I took it to a Ford dealer to diagnose and repair, and it was in fact the Blend Door; just as already suggested by bobneu. It was a little pricey though, just less than $1000.00 for the dealer to repair, due to the fact it is located under the dash that had to be dismantled to get to it. Most of the cost to repair was labor, not the part, that was less than $50.00. If you do know someone who won't mind spending the time to dismantle the dash and putting it back, then I definately would go that route. It will cost alot less than taking it to a dealer.
Nov 09, 2008 | 2002 Ford Explorer
Honeywell cm61 controller
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Dec 23, 2007 | Honeywell Programmable Thermostat Heater
Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Dec 02, 2007 | Marvel 61WC Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
837 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
