Question about Coleman 36qt Xtreme Cooler
Broken hinge Colman cooler
We have a nice Colman cooler but the hinges have broken. My husband can replace them if we can obtain new hinges from you. Please respond to either 1-574-533-3839 or email: Edie@EdieGray.com
Thanks.
Edie Gray
  • lroberts48 Feb 27, 2009
    coleman 70qt. extreme---- broken hinges can I replace with stainless steel hinges?
I have three colman coolers with broken hinges. I would like to find some new hinges to replace them . model # 6270 6273
Posted on Oct 25, 2008
  • ken higgins Apr 23, 2012
    you can remove one and take it to home depot to match it up--or google colman and order a pair of new hindges for about $6
Looking for hinges for a thermos 55 ice chest cooler
check the website. i know you can get colemans from theirs
Jan 02, 2018 | Thermos Grilling
Where can I find a replacement hatch for my dockside 25 igloo cooler. The product line is not listed on the igloo website
Go to www.coolerhinges.co
Under bestsellers click on 4. cooler shield cooler hinge type I igloo pair. 14.99 plus 5.00 shipping. Lifetime warranty.
If you need 3 hinges click on 2. cooler shield cooler hinge type I igloo three pack. 21.99 plus 5.00 shipping. Lifetime warranty.
Phone 1-888-810-7283
Jun 08, 2014 | Igloo DOCKSIDE 25 Pier Fishing Cooler
FB 510 Cuisinair built in oven - how to replace door hinges and where can new hinges be obtained
Assume you have lifted the door off the oven. You may have to dismantle the door to replace the hinges. Take a hinge to an electrical appliance parts supplier to get new ones or ask stockist of this brand.
Jan 03, 2011 | Zanussi Ovens
I have a Cooler Master, Wave Master alumininm computer case that has served me well. This case has a small compartment on the top that contains a couple of USB ports, etc. Recently the small black latch...
I don't think you can get that as it is almost impossible to get parts like that. But this might be an idea for you .... if its hinged use Velcro strips on the face where the hinges are ... now the Velcro will show but its available in black or white ... make sure you use only the fuzzy side as the other things like dust will stick to it ... now remember you are only using it to replace the hinge and you will use it like a piece of tape, So place compartment where it belongs in closed position and place Velcro strips over the case and cover now the Velcro serves as the hinge ... I have this on my PC and it works great!!! good luck
Sep 29, 2009 | Cooler Master Wavemaster Aluminum Computer...
The locking lid on Crock Pot SCVS600 has broken.
I had this same broken lid handle problem so I called the 800 number on the crock-pot.com website and got right through to a live person. Since my product is still under warranty (they asked for the manufacturing date code on the plug), instead of providing me a replacement part, which the very nice woman said is unavailable, they are sending me a whole new crock-pot. Not the same model (which the nice woman also said is unavailable) but a comparable unit which is OK with me. Maybe this is their solution to the lid hinge and handle problems.
Dec 24, 2008 | Rival SCVS600 6-Quart Slow Cooker
Loose hinge razr v3
http://www.hackthev3i.com/pdf/MOTOROLA_V3i_DISASSEMBLY_GUIDE.pdf
this link shud give you enough guidance
All the best.
Hope this works for you
Tc
Have a nice day!
Jul 01, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
Broken Hinges
I removed the hinges and drilled the flat end of them with a half inch drill. There is a spring inside that needs to be removed. It works fine now, except that the lid needs to be propped open when changing ink ( I use a plastic chop stick for this purpose).
May 08, 2007 | Brother MFC 3820CN All-In-One InkJet...
Coleman 36qt Xtreme Cooler Logo
1,449 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
