Question about Sony KDF-E55A20 55 in. LCD Television
How do I get to the bulb?
I have A KDX-E55A20. It needs A new buld How do I get to it?
  • Anonymous Mar 06, 2009
    How do I get to the bulb.
  • 10,594 Answers
You can buy Original Lamp for your Sony KDF-E55A20 from Sony Accessories (Official Website of Sony) by entering model number as above in search box.
For your information, Lamp (bulb) part number is ...
A1085447A* LAMP BLOCK ASSY XL-2200U and price is approx $200
Thank you.
Posted on Oct 03, 2008
How do I replace bulb in oven? Stoves el716 what is bulb part order number?
you can remove the bulb first then go to the local pound shop or a hardware shop or even morrisons or tesco the buld will be a standard screw in but has to be an oven buld not a normal one ive found these bulbs in the local shops easily do not use any unhardened buld for the oven type i replaced one the other day as usual i got a pack of two from the local hardware guy for a couple of quid
Oct 18, 2014 | Ovens
Wired in new directional on sportster wont flash
From your description, it sounds like the new bulbs (that won't flash) are LED bulbs.
When you replace the stock Harley incandescent bulbs with LEDs, you NEED to add a LOAD EQUALIZER to make the bulbs flash:
http://www.jpcycles.com/product/381-877
The amp draw is different with LEDs, and they won't flash without the equalizer.
May 06, 2014 | 2001 Harley Davidson XLH Sportster 883...
How do u change bulds an where they at
bulbs do not get changed as it has picture tubes--sounds like a convergence problem--replace the two STK-392-110 or 150 chips it has.
Jun 14, 2012 | Hitachi 51F510 51" Rear Projection...
The bulbshead lights keep going out,
If you are replacing the headlight bulbs and just a short time their bad again you need to change your techniquie in installing the bulbs. You can't touch the lens of the bulb with anything ( not your finger) or the bulb will overheat in operation and burn out. with the old bulb out and the pulg laying out to where you can get it or someone else holding it. Open the package the new bulb comes in so just the plug end sticks out of the package. holding the bulb by the package install the buld into tne socket and them hold the socket only to put it into the back of the headlight with out running into any thing as touching anything can cause the buld to fail/ If the light fixture is getting water or dirt inside of it it will need to be repalaced.
Mar 04, 2011 | 2004 Hyundai Elantra
I it easy to cange the lamp in my e55a20 sony tv. I have one coming 2moro, and was wondering the difficulty level.
It involves removing a housing an pulling out the bulb then inserting the new bulb and replacing the cover. Sony has excellent instructions in the owners manual:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=KDFE55A20
pg 76
Mar 02, 2011 | Sony KDF-E55A20 55 in. LCD Television
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
Nov 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
I am replacing the bulb on my Sony lcd tv. I am waiting for the new bulb (with housing) to arrive and decided to practice. I pulled the old bulb housing out and slid the new one in. Seemed very simple but...
If you lost video and assumed the fluorescent tube was at fault, you may not have guessed correctly.
There is a power supply (normally called an inverter) which may be separate or combined with the main supply that produces the high voltage the back-light requires. The tubes, if bad, will have a well-defined dark area at one or both ends of the tube. If the inverter has failed, there will simply be no voltage to ignite the gaseous tube.
The effect is the same but the solution is different.
Jul 15, 2010 | Sony KDF-E55A20 55 in. LCD Television
My sony kdf e55a20 cuts on and off, but the lamp indicator never turns on
Order a new bulb, easy to replace, just read the manual. In the meantime, go into Settings and change the Power to Power Saving, instead of Standard. Your bulb will work fine until the new one arrives.
Dec 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv projetion lg model rp-60sz30
You need a new bulb. It's easy to install. Remove the lower panel. Remove the 2 screws that hold the buld casing. Remove the bulb and replace with a new one. Replace the screws then the lower panel.
This will save you about $300 in so called labor.
Sep 17, 2009 | LG RU-60SZ30 60" Rear Projection...
Kdf-e55a20
In my experience with these models, if have found that your fault could be due to a blown bulb assembly. This can easily be checked by looking up the bulb replacement procedure in the user manual. The bulb should look clear and see-through to the tip of the filament. There must be a small class pipe inside which has a wire connected to the tip.
Any white residue or black discoloration inside the bulb indicates a blown bulb. You can contact your nearest Sony service centre for a new replacement bulb. Write down the "XL-xxxx " number as you will have much faster result than giving the model number.
If you need any more assistance please post a reply.
Best of luck.
Mar 02, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
