Question about Epson PowerLite 720c Multimedia Projector
Epson powerlite 720c projector
Just purchased a used projector and the image has a green line horizontally a little above the halfway point. The portion of the image above the line is lighter than the lower part and the far left portion of the screen has a very red tint to it from top to bottom. The edges of both of these tints do not seem to fade but are pretty definitive. The lamp has 720 hours on it. I am using component video on a 25 foot cord from a dvd player to the computer connection on the projector. I have tried both inputs for component video and this is the best.
Is there hope for my projector or is this a major problem?
SOURCE: Lamp is on but not no signal from projector coming out !!!
i figured it out. open it up, and make sure the ribbon cables are securely plugged in.
Posted on Apr 03, 2008
SOURCE: greenish tint
Not sure if this is the solution, but I believe the color polarizer filters have been burned. I have a yellow haze circle on mine and I'm pretty sure that's the problem. In my case the blue filter is burned, leaving the red and green stronger yeilding a yellow blur.
Posted on Jan 04, 2009
dhiman
  • 115 Answers
SOURCE: the powerlite S1 projector has
check the fly eye lens and then Lamp unit. Service and check the LCD panels.
Posted on Jan 12, 2009
  • 6 Answers
SOURCE: The color on my Epson
Two possible solutions:
1) The video mode is set to Component/RGB instead of VGA.
2) The cable you have may have a break inside of it.
Let me know if you find anything.
-Jeff
Posted on Mar 18, 2009
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
How do I fix Color wheel problems
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 17, 2014 | Epson (DHV13H010L18) Projector Lamp for...
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
My epson projector is displaying purple,pink and other colors. i changed the chord but still the same problem
means that the lcd panel is fault or the polarizer is burned
Jul 26, 2011 | Epson (DHV13H010L18) Projector Lamp for...
The projector is projecting everything in a purple tint.
The projector is projecting everything in a purple Does it need a new lamp
Feb 02, 2010 | Epson (DHV13H010L18) Projector Lamp for...
Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
Images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Mar 14, 2009 | Epson PowerLite® S4 LCD Projector
The projector displays pink or red not full color
Hi GiantBryan
If switching the cables did not work , then this is a faulty Mainboard that will need either repair or replacement as discolouration on a Projector could only be the cables or the Mainboard.
May 12, 2008 | Epson (DHV13H010L18) Projector Lamp for...
Image.xson Power Lite 730c
I had this problem with a Mitsubishi and it turned out to be the cable.
Oct 26, 2007 | Epson (DHV13H010L18) Projector Lamp for...
Epson PowerLite 720c Multimedia Projector Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
