Question about Epson Stylus C86 InkJet Printer
Black line is printing (left side of Page) on every page
  • Anonymous Jan 16, 2009
    Same thing. In fact, I'm a technician and I've had this problem with every brother printer I've worked on....
    Problem Solver:
  • 7 Answers
Make sure you are buying good quality ink, you can purchase your ink at its best price and quality at www.Yahootoners.com
Posted on Jun 04, 2009
You need to change drum.
Posted on Feb 14, 2009
3 Suggested Answers
SOURCE: White line appearing vertically down the left side of the page
I had a line for months! Then I got a line going down the middle of the page. So cleaned and poked around inside put back together and another line! 3 vertical lines! Came on here and went back with a hairdryer on cold setting blowing around the inside of the printer and now its perfect!
Cheers all!
Posted on Apr 04, 2008
geo_jonas
  • 555 Answers
SOURCE: prints only on left side of page.
In printing web pages and email please try to check also the print setting before you print the page cause word document files and web pages are not the same in there printing setting. Web pages and emails has different setting so my recommendation is that when you print email and webpages next time then please check the printer settings then modify it the same settings as you wish or as your word document's output.
Thanks
Posted on Aug 18, 2009
On left hand side of page horizontal line
You might have touched the main charger cleaner a green part above the waste toner container. just push it inside and try to copy and print
May 11, 2010 | Copystar Office Equipment & Supplies
A vertical black stripe is printing on the left side of the page.
Have you tried replacing the toner cartridgein the printer? If you print a page then remove the toner cartridge, carefully open up the cover that covers the the drum on the toner cartrdige.You can often see a line that corresponds to the line printed on the page.
Oct 13, 2009 | HP LaserJet 1022n Printer
Line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
Oct 09, 2009 | Office Equipment & Supplies
CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Jun 05, 2009 | Xerox CopyCentre C20 Black and White...
Cs-2030 leaves a black line on left side of page...
The waste bin might be full,try emptying it. Also check the photoconductor unit
May 26, 2009 | Copystar CS-2030 Copier
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Epson Stylus C86 InkJet Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
