Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Can someone show me a diagram of explane how to replace my belt? thank you all very kindly
2 Suggested Answers
SOURCE: belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Posted on Feb 28, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube
    • 3 MIN
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ...
    • 5 MIN
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
    Jul 15, 2016 | Washing Machines
    Belt replacement
    belt goes on the bottom of dryer. look up your model on internet on replacing belt . its pretty easy. if old belt is still on make a diagram of how belt goes on, also take a pic.
    Jan 30, 2014 | Amana DLW330RA Top Load Washer
    1996 geo prizm 1.8 ltr lsi timing belt replacement diagram
    Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
    Click the link below: ----
    ----------This will help. Thanks.
    Feb 02, 2012 | 1996 Geo Prizm
    Please show diagram for replacing serpentine belt
    How do you bypass the serpentine belt from the a/c compressor the reg belt is 85in
    Oct 25, 2009 | 1999 Ford Taurus
    Replaced my zanussi tc-481w drier belt but it still won't work
    Success! I found a clear explanation of the problem I was having and a diagram when someone recommended typing the model number into the Wiki how web site .
    Result! Thanks for your help.
    Nov 18, 2008 | Zanussi TC7114W Electric Dryer
    Replacing Drive Belt on a Hotpoint TL22 Drier
    great site now i know exactly what i knew previosly... NOTHING
    Aug 06, 2008 | Dryers
    Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
