Question about Car Audio & Video
Car radio citroen xm radio/cassette screen very dim. boffin says bulbs probably blown.How do you change bulbs --if at all. I can't see any way in!
  • 25 Answers
Remove radio unscrew front of radio to expose circuit board and desolder and resolder a new led onto circuit board then replace unit
Posted on Feb 18, 2009
Where is the dip/dim relay on my citroen relay 2ltr hdi 2002
Replace the dimmer switch is the best guess on this.
Sep 05, 2016 | Citroen Cars & Trucks
Why is it that when i turn on the stereo the backlight is too dim i cannot see what radio station that i tuned in.
You probably have burned out bulb(s) behind the display. Unless you are good at desoldering and soldering, it is recommended you have them replaced by a professional.
Aug 18, 2011 | Alpine TDM-7561 Cassette Player
My car doesn't have a cassette player, an audio jack, or an exterior antenna for xm sure connect, is there anything else i can get for it to play?
You need a FM direct adapter its plugs in behind the radio in your antenna. the part number is FMDA25its says Siruis but it works for XM.
Feb 16, 2011 | XM Radio (XMP6000)
Dim radio/cd player display
The Bulbs have blown you can get special bulbs from the renault dealer have to pull off to of dash to fit
Dec 04, 2009 | Aiwa CDC-MP32 CD Player
Delphi XpressRC XM Radio backlight problem
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Sep 17, 2009 | Delphi XpressRC XM Satellite Radio...
Cassettes being ejected automatically
The belts are probably shot in the cassette player that's 13 years old. You can probably buy another radio like it and just change out the cassette portion if you are a good electro-mechanical person.
Apr 22, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
I have a bose stereo in my 96 nissan Maxima that works poorly
there is a problem in the tape drive - possibly a bad belt- thats why the cassette adapter keeps ejecting itself- most add on xm tuners have the ability to broadcast its signal wirelessly-you press the menu button then turn the tuner to select the menu option that you want then press on the tuner control again to choose broadcast (fm signal and which channel you want to broadcast to the factory radio-try www.xmradio.com for more detailed info
Apr 16, 2008 | Car Audio & Video
Car Audio & Video Logo
176 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
