Question about GE Microwave Ovens
No lights not working at all - GE Microwave Ovens
  • ChiliDog62 Nov 17, 2008
    Model- JVM1860SD001 lights quit working. Replaced all 3 bulbs (1 in oven and 2 range lights). Everything else working fine.
Model JVM1860SD001 lights quit working. Replaced all 3 bulbs (2 in range and 1 oven light). Everything else works fine.
Posted on Nov 17, 2008
Rear side marker light goes out car when driving other lights work when driving
This problem is misscatagorized under microwaves. Should be with cars
Apr 13, 2014 | Emerson MW8107WA Microwave Oven
Lights not working
follow this steps and fix it God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gPpzp9iL
Sep 30, 2013 | Amana Microwave Ovens
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Light will not work even with new bulbs. Fan
one of your micro swichts are bad.
Dec 21, 2009 | Microwave Ovens
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Microwave oven work light doesn't work
Then you have bad light socket or some broken wire to this socket.
Nov 30, 2008 | Microwave Ovens
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Hood Lights not working
The problem lies in the circuit board / control panel. We regularly repair these control panel assemblies nationwide for 32.50.
Oct 06, 2006 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
161 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
