Question about Comdial 8324S-PT Corded Phone
Comdial speaker phone not working
We just received headsets and when we turn them off to us the handset our speaker phone part will not work. what am I not doing?
  • Carl Navarro
    Carl Navarro May 11, 2010
    According to the manual, nothing. Lifting the handset cancels the headset, but it doesn't say anything about the speakerphone working with the headset plugged into the AUX jack.
    Just for fun, either press the headset button so it's not lit, or program another button for something else (another feature). To do this, find a spare button and dial intercom **1 the button and dial 95 or 96 or 97 and TRSF.
    Now you have a button for HEADSET and another feature. Press the other feature button and then see if the speaker works. I don't expect it to, but I don't have my Impact set up here to test it.
3 Suggested Answers
keekus
  • 83 Answers
SOURCE: headset compatability
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Posted on Jul 18, 2009
  • 69 Answers
SOURCE: Can't activiate the headset feature.
it has to be setup from programing you need a tech
Posted on May 09, 2010
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Good luck from Headsets Direct!
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
How to use a headset for comdial 7260-00 HAC?
I'm guessing you already figured out how to plug it in, so the next thing is to enable it :-)
FEATURE 9# enables FEATURE *9# disables.
The Speaker On Off controls the headset after it's enabled.
Carl
Oct 23, 2010 | Comdial 8324S-PT Corded Phone
Does the comdial 8324sj-fb have a headset jack on the base?
I can help you with your Comdial 8324sj-fb phone question.
Yes, there are three jacks on the bottom of the Comdial 8324sj-fb: One is for the line cord, the second is for the handset, and the third is for a headset.
I hope that helps.
_____________________________________
Comdial 8324S Station Manual Download
Comdial 8324S Reference Manual Download
May 27, 2010 | Comdial Impact 8324SJ-FB Corded Phone
Speaker works but handset does not. replaced
Make sure to use a new handset cord as well. Also, make sure the handset is plugged into the handset jack under the phone. The 3102 phone has a headset jack that will not work with the handset. There is also a button mapped by default in the upper right corner that toggles from handset to headset. If the light is on, then it is set for headset and the handset won't work.
Dec 18, 2009 | 3Com NBX 3102 IP Phone
I need the pinout for the Avaya 2400 series telephone headset RJ-11 Jack.
I noticed that Avaya headset is different from the Avaya handset or any other standard headset: The outer two pins are switched.
Avaya-Headset-pinning is like this:
Look to the RJ11 and turn it until you see leads from top and from front, then from left to right you look at
1) mic 5V
2) speak
3) speak
4) mic gnd
RJ11 of Avaya-handset and any standard headset/handset from the supermarket:
1) mic gnd
2) speak
3) speak
4) mic 5V
Hope that helps.
Stefan
Nov 24, 2009 | Avaya 2420 Corded Phone
Headset compatability
To Re-Subscribe:
Apr 22, 2009 | Comdial 8012S-GT Corded Phone
1) No dial tone in the handset 2) speaker key will not work
You have the headset feature active on your phone. You more than likely dialed the headset code inadvertently, there are two ways to turn this feature off. 1) If you have a headset key programed on a key on your phone turn it off. 2) Dial the headset off code, you can obtain this from your local admin.
Sorry I didn't have quick fix for you.
Mar 13, 2009 | Mitel 5220 IP Phone
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Jan 29, 2009 | NorStar Meridian M7310 Phone
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Dec 17, 2008 | Polycom SOUNDPOINT IP 501 SIP
Comdial 8324S-PT Corded Phone Logo
124 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
Starnley Johnwells
Starnley Johnwells
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
