Question about Maytag MER5775Q Electric Kitchen Range
Bottom oven element
The bottom oven element is bad. I removed, but the two connectors are not fixed to back wall. They seem to be loose behind it. Cannot simply push new element through holes to connect.
Do I need to pull stove out and remove back panel to access connectors so I can connect to element? Is the back panel easy to remove?
  • rturne Nov 05, 2008
    Thanks to rv1234 for the response. The advice is good. I have already replaced the bottom element and that did not solve the problem. When the bottom element disintegrated, it evidently caused a brief short that fried the circuit board. A common problem with this stove. With a new element and circuit board (called a clock/overlay), the oven works fine.
    Scholar:
  • 62 Answers
Yes you will have to remove the back panel , but first shut off the breaker to the stove as one of these wires go directly to the power cord. Normally I would tell you to unplug it but in trying to move it out you may cause one of the wires to touch the frame and ZAPPP you! So please b4 you go farther shut the breaker off. Once you have the stove pulled out, it should have several screws that hold the back on. Not a big deal. Push the element through and connect the wires. In the future be very careful as you are pulling the element out and usually the wires will stay connected and you can replace the element from the front. Just remember to shut the power off first!
Posted on Nov 05, 2008
How do I replace the bottom oven element on my Maytag CWE5800?
This shouldn't be too difficult. Make sure the power is off. Remove the screws that hold the oven element in place. carefully pull the element out from the back wall without losing the wires back in the holes. Install the wire on the new element push it back in the wall. Reinstall the screws and you are set. Turn the power back on and check to make sure the oven cycles when it reaches the set temperature.
Feb 08, 2014 | Maytag Ovens
When I switch the bottom oven switch on the fuse blows in the electric box. Please can you advise if a wire is loose and how to fix it.
Sounds like your element might be blown and shorting. Switch the appliance OFF. You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
Mar 31, 2011 | New World Ovens
Need a manual for kenmore electric 164D3871P002. The bottom element is bad. Thanks
Sorry, I don't have a service manual, but I can give you the general procedure for removing the bottom element (replacing is the reverse procedure).
  1. Unplug the oven
  2. Pull it away from the wall far enough so you can work behind it see what you are doing.
  3. Remove the screws from the back panel behind the oven. Sometimes there are additional plates, covers or baffles that need to be removed to let the back come off. Make notes as you go if you are concerned you may not be able to keep track of everything for reassembly. This is the hardest part of the job.
  4. Take a peek inside the oven at the back where the element attaches to the wall. If there are screws holding the element there, remove them. You will be looking for the corresponding location behind the oven in the next step.
  5. Identify the two wires going to the oven heating element terminals. They are almost always attached to the element with screws, but a few may use push-on terminals. Disconnect these wires. If push-on terminals are used, do not pull them off by pulling on the wires; grasp the terminals themselves and pull while holding the element terminals with needle-nose pliers. If necessary, polish or replace any burned terminal connectors.
  6. Remove the old element and do any needed cleanup inside the oven.
  7. Set the new element in place and reverse steps 5-1.
Almost all electric ranges have a wiring diagram somewhere in the back, sometimes on the inside of the back cover. If you find it, look for the item marked "oven heating element" or a similar name (not broiler or upper oven element, of course). There should be abbreviations next to it for the colors of the wires, with the solid color listed first followed by the stripe color (e. g., RED/GRY for a red wire with a grey stripe). This will help you confirm that you have the correct wires (it is unlikely that there will be anything else in that area of the oven except the connector for the power cord). If you get mixed up about which wire goes to which terminal on the element, don't worry, it works the same either way in this case.
Jan 19, 2011 | Kenmore Kitchen Ranges
How do you replace bottom element in top oven?
Turn off the power to the oven at the breaker box.
Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
Pull the element toward you a little bit until you see the wires behind it.
Unscrew the leads and take the bad element out.
Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
Fasten the brackets, making sure they're tight.
Restore power to the appliance.
Dec 23, 2010 | Ovens
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
The double oven works on top oven only, bottom over does not operate. Occasionally an error message comes on but usually bottom oven digital readout shows nothing. Do I just need a "selector switch with...
hello,
what this error message means no the screen is that there has been a loose of wire from the connection or loose of wire from the element that i the heat provider (heater)on the below oven unit
the failure of the below oven has nothing to do with control switch from your statement or explanation .
what you will have to do to fix up the problem of the oven is to unscrew (open) the oven from the stroll with a stroll driver (tools) from behind then trace the wire (power connector from the switch ) down to the element beside (left or right)Conner of the oven silver in color to see if there is any form of loose wire from this position , if yes then you will have to fix up back to the element with care with out disconnecting any other wire from it position ,but is non the it then mean that the element will need a replacement
thank you and thanks for using fixya
Jul 19, 2010 | Ovens
How can i change my omega oven element and how to i find out how many watts the old element is
Hello,Is your element fixed to the back wall by (1)Two Phillips head screws or (2)the ends of the element are about "8" apart and held in with 2 clips.Switch off the power on the main switch board marked RANGE,STOVE OR OVEN.
In case of (1) unscrew and take the element out,pull off the 3 push on connectors,get new element and do it in reverse.
In case of (2) get a small screwdriver,push the clip just above the tube from the element going to the back and the clip should jump out,do the same for the other side,lift up the element a 1/4 and pull it out carefully not to loose the cable as they are very short
Thanks
May 28, 2010 | Ovens
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Hotpoint stove oven
This is a simple step-by-step procedure.
1. Turn off the power to the oven at the breaker panel. Or slide the oven ahead and reach behind to unplug the power cord.
2. Take out the two screws holding the element bracket in place. These will be on the back wall of the oven. They are usually hex head or phillips screws.
3. Carefully pull the element toward you a little bit until you see the two wires behind it. Unscrew the wire leads and remove the bad heating element.
4. Handle the new element carefully while you attach the wires to it. Don't stretch the wires any more than you have to.
5. Line up the new element while tucking the wires back in place. Be sure not to pinch the wires between the bracket and the back wall.
6. Fasten the bracket screws, making sure they're tight.
7. Restore power to the appliance and start your oven to check if the new element heats up.
A few things to remember...
You are working with high voltage! Be sure the power is off or the oven is unplugged!
If you find one of the wires has come off the old element, simply reconnect and check your oven. Your old element may work again and you will not need to purchase a new one.
In removing any of the screws mentioned above, note that they may be difficult to lossen due to years of exposure to heat. Don't give up, they will eventually loosen.
Your new element may have some oil or other gunk on it due to the manufacturing process. Once it begins to heat, it may start to smoke. Don't panic! Any residue will eventually burn away and the smoke will cease from then on.
Good Luck!
Mar 04, 2008 | Kitchen Ranges
Oven will not heat
Most likely, your lower heating element has failed and needs to be replaced.
This is a simple step-by-step procedure...
4. Handle the new element carefully while you attach the wire leads to it with the old screws. Don't stretch the wires any more than you have to.
Good Luck!
Dec 22, 2007 | Frigidaire GLGF377 Gas Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
123 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
