Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub 353p error c - 4551
Hello, I am receiving this error message on our brand new printer. It's a bizhub 353p. It says to open the front door then close it to reset, but it keeps coming back. I can't find any obstructions or jams, i've tried power on/off, and unplugging it for a while - still comes back! Does anyone have any ideas on what this problem could be?
Thanks for your time!
  • 2 more comments
  • FCL-Tech Oct 07, 2008
    I called Konica, they came out and spent 3 hours putting in a new imaging unit for the cyan color. Everything is fine now, must have been a bad one from the factory... Tech said that standard operating procedures call for all imaging units to be replaced when 1 goes out, but since this machine is brand new, he just did the one. Thank heavens for good warranty!! Side note, Konica tech support is the absolute best i have ever dealt with. There was a guy here within 45 minutes after 1st call was made. He stayed all day, even left and came back with parts and didn't leave until it worked. Used to have to deal with Xerox, they are the absolute WORST tech support i've ever dealt with. It would take them days to get here, and when they did they would often (at least 4 times this has happened) start troubleshooting the wrong machine, then when told that it's a different machine, they would say "well i'm not certified to fix that one, you'll have to place another service call." The only difference in the models was one was blk/wht, the other one color. If you value productivity in your business, do not buy xerox.
  • Anonymous Nov 12, 2008
    Exactly the same problem. Replasing all image units give me nothin
  • tlequestrian Nov 20, 2008
    Same Problem and I have TONS of printing to do for billing!!!!
  • Brandi B
    Brandi B Dec 26, 2012
    Save yourself the headache and buy the chips pff ebay. They have you replacing drums that are WAY before their time just to make you spend more money.
C-4153 Laser malfunction (Cyan)
SOS signal is not detected even after the lapse of
a given period of time after staring the laser output.
• SOS signal is not detected for a given period of
time during printing or IDC sensor adjustment.
Replace the PWB Print Head assy
Posted on Jan 14, 2009
  • 167 Answers
Faulty door sensor?
Sounds like the door my be loose or mis-aligned.
Posted on Oct 07, 2008
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ... > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
How do i clear error code c4154 on bizhub c250
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Oct 17, 2015 | Konica Minolta bizhub C250 All-In-One...
Receiver exchange error message
replace the trim waster with a new one
Mar 23, 2014 | Konica Minolta Bizhub C 6501 Color...
P-21 and p-5 error message. and fully cyan color comes.
here is the link
if you have any problem contact me.
Nov 27, 2011 | Konica Minolta bizhub C250 All-In-One...
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How do you do a hard reset on a Bizhub c350? Thanks.
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Bizhub C253: Error Code C-4551 will not clear. Any ideas?
open front door and switch-off machine
press utility buton hold press-on then swietch-on machine, on the screen right top corner u see dot (remove finger from utility buton)
after fue second u will see trouble reset touch under u will see ok switch-off machine wait 10 sec and switch on
If the error code still is on the machine u have to change cyan laser
Oct 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Our bizhub-250 receives a C2557
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Mar 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub c250 error code
the problem is
"An exceptional
instance occurred
due to the unexpected
Parameter in
the System F/W"
you need to upload a new f/w to the copyer
best reg
pini - israel
Feb 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,066 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
