Question about Kitchen Ranges
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
  • Kitchen Ranges Master
  • 744 Answers
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Paul is from the Naturally he would appreciate beer How to Repair Home...
Posted on Apr 06, 2014
    President:
  • 1,462 Answers
Have you got clock set to auto by mistake?
Posted on Oct 03, 2008
I have power but not switching on at Knob no grill or oven no fan
Beko OIF21300B Electric Single Oven not heating - Repair
www.how-to-repair.com/.../beko-oif21300b-electric-single-oven-not-hea...
Jun 11, 2015 - If your Beko OIF21300B Electric Single Oven is not heating or tripping the ... Now the cooker turns on and the display lights come on but the cooker does not seem to work and start heating up. ... The grill element doesn't work
[PDF]Download Manual - Beko
downloads.beko.co.uk/bekoupload/manuals/DVG592.pdf
Congratulations on your choice of a Beko quality cooker which ..... Before you startusing your cooker, clean ... if an appliance burner doesn't light, press again.
Dec 13, 2015 | Beko D533AW Single Fan Oven Electric...
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
Beko oven does not fully heat up
If you have a problem with your beko oven not heating then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Mar 29, 2014 | Ovens
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
Beko DVC5622X bottom oven wont heat up
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Oct 27, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Nov 19, 2010 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Kitchen Ranges Logo
962 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
