F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a
handy guide with pictures showing you what's typically involved in standard models.
Here are specific details on your model:To
replace the control panel, you will need to remove the microwave from
the installation. You will also have to remove the top access panel.
Before
removing the microwave from installation, disconnect all electrical
power to the oven by turning off the appropriate electrical breaker.
Here are the steps for removing the control panel:
1. Remove the oven from the cabinet or wall opening.
* CAUTION: Do not use the oven handle to lift or lower the oven. Damage
will occur.
* Be careful that electrical conduit is not caught or stressed during
removal.
* This step requires 2 people for removal. The microwave should be
grasped from the bottom and the front and rear of each side during
removal.
* Remove the 4 mounting screws located in the front oven frame.
* Carefully slide the oven forward and out.
* Lower the oven onto a protective surface for servicing.
2. Remove the top access panel. There should be 9 screw attaching the top panel.
3. Disconnect all connector plugs on the control panel. CAUTION: Be
sure to note the location and routing of wires for proper
reinstallation purposes.
4. Lift the control panel to disengage the lower hinge tabs from the chassis.
5. Remove the control panel.
You can usually find helpful exploded view diagrams and order parts by entering your full model number
here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.William E. Miller, AS-EET
[email protected]http://www.microwavedisplay.com
