HP OfficeJet 6110 All-In-One InkJet Printer Logo
Posted on Oct 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set speed dial numbers? - HP OfficeJet 6110 All-In-One InkJet Printer
Anonymous
Level 2:
Scholar:
  • Expert 105 Answers
  • Posted on Oct 06, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
105
Questions
0
Helped
53859
Points
206
Here is the procedure to setup speed dials (both individual and group) on your printer.
thx
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
3helpful
We have a new wx345 cell phone that we have set up with speed dial numbers but I do not know the procedure used to call or dial any of the speed dial numbers. Can you help us use our speed dial?
If you have set up your numbers with speed dial, make sure the speed dial option is set "ON". When you are ready to make a call, press and HOLD the speed dial number you are calling. I had the same problem and found the solution on another online forum.
May 20, 2011 • Cell Phones
4helpful
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
4helpful
2answers
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
1helpful
Program and use speed dial numbers
speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
1helpful
2answers
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 • Nokia 1100
How do I set up and use speed dial on a Toshiba dkt2010-sd
what system u using??
if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
- to set speed dial press REDIAL SPEED DIAL standard speed dial   code 60 or 600, follow by 9+destination number, REDIAL to confirm.
- to call press speed dial + code or press * + speed dial code (*60 / *600)
- if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number #
- to dial press *200...
1helpful
How do I set up speed dial for a Toshiba DKT2010-Sd phone
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
k24674
Grand Canyon Tech
Grand Canyon Tech
