Question about Farallon Computers & Internet
Network cable need a PCMCIA to RJ? cable for ATT internet service. (Cable provided by ATT broke.) Cable is Farallon TE579 6070702-00-01 How and where do I get one? Tahnks - Kenny
  • 83 Answers
Cables To Go.
Posted on Jan 03, 2015
    Problem Solver:
  • 12 Answers
I want to say just one thing that use Ethernetpedia App.then u understand many thing realated to it.
Posted on Dec 20, 2014
    Scholar:
  • 108 Answers
Http://www.dealtime.com/xPP-Network_Cables--farallon
Posted on Jan 15, 2009
Linkserve pvt ltd mali, malidives
Posted on Nov 01, 2008
Hook up an ASUS N13U Router to a Speedstream 4100 Modem - ATT DSL
Both the modem and the router should have an ethernet cable connection. The modem probably has only one, the router may have more than one. Look for the one on the router labeled WAN or INTERNET or MODEM connection. Connect the two with a standard 8 pin RJ-45 connector cable.
Then, ordinarily, just reboot each. Turn off the router, reboot the modem, the turn on the router. It should connect automatically.
Sep 21, 2013 | ASUS RT-N13U Wireless Router - 300 Mbps 1...
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
What jack does the Slingbox Ethernet cable hook into on a ATT 2wire modem? I have a choice of DSL or one like the phones are hooked into. It's not working now so I'm backing up each step, no matter...
Before you change anything - is this a new device you are hooking up or had this thing worked in the past? First thing to do is reboot everything starting with the modem and ending with the computer at the end of the line. Wait at least 30 seconds between each device. Review all the connections - everything plugged in where it should be? (this is of course your question - see more below).
Eithernet connections (plugs) are RJ-45. The RJ-45 looks like a RJ-11 (telephone jack) only bigger. Typically, the RJ-45 will not fit into the RJ-11 AND SHOULD NOT. Why? Your Cat 5 eithernet runs on very low voltage and signal (packet switching). If you succedssfully get the RJ-45 CAT 5 cable into the RJ-11 phone jack, when the phone rings, you will be sending 60 volts into your network. Can you spell "Do I smell smoke?" A RJ-11 will have up to 6 wires (one pair or two pair or three pair) in the jack and up to 6 'buds' on the RJ-11 plug. A RJ-45 will have 8 wires (in the jack) and 8 'buds' on the plug of your cat 5.
Your device may say DSL on the Cat 5 connection - count the wires inside or the jack.
There are other Cat 5 connection types, punch down and terminal screw types, I dont think you are talking about either.
On your AT&T modem, you should find a RJ-11 which will attach to a near by telephone jack and a RJ-45 for your Cat 5 cable. Your modem may also serve as a router and as such would have additional RJ-45 ports. I suspect you are using a separate router for your home network. As such, one of the ports on the router should be marked Internet or Upload or maybe it is a special color or is set aside from the other ports. That special port will be connected to your modem and your other computers will use the other, lesser ports.
Of course, you could call your service provider for clarification also.
Thank you for your question @ FixYa.com - I am sorry you are having this trouble and I hope I have helped you in some way. I hope you are able to get your system back up in short order.
If you are pleased with this response, please consider awarding the coveted 4 thumbs up to this response. Thank you
Aug 08, 2011 | 2wire Computers & Internet
How to connect dsl cable with generic android tablet pc
What you need is a wireless router which is connected with the dsl cable and it should be configured to broadcast signales, ip addresses and security etc. Usually this service is provided by Internet service provider companies (ISPs) which give dsl connection. If your generic android PC has a network connector port (called RJ-45) built in then there is a chance that you can directly connect it with the dsl cable otherwise you have to take Wifi signals from the wireless router to get internet in the device.
May 18, 2011 | Computers & Internet
I want to connect a CAT5e Ethernet cable (with or without a RJ45 connector) from a DSL router to an older computer that only has a RJ11 input. This will be used for DSL internet service only -- no...
The only "outputs" from a DSL-router are:
* RJ-11 telephone-jack, only if the router also supports voice-over-IP,
* RJ-45 Ethernet port (always present)
You need to purchase an internal network-card, to create an RJ-45 port on the computer, and then use the CAT-5e cable to make the connection.
Feb 20, 2011 | Computers & Internet
I'm having trouble connecting my emachine to a cable modem.
Turn off the computer before you begin making connections. Make sure the cable modem is up and running with your service before you attempt to make the computer connection.
  • 2 Connect the coaxial cable from the wall outlet into the back of the cable modem where it is marked "Cable" and has the male coaxial connection. Use an extension coaxial cable if necessary to reach the modem.
  • 3 Connect the CAT 5 networking cable from the cable modem where it is marked "PC" (or something similar) and connect the other end into the back of your computer where the networking card is. These connections are RJ-45 connections that look like oversized telephone jacks. If you also have telephone service through your cable provider, you will want to connect the telephone line into the port on the back of the cable modem marked "Telephone."
  • 4 Connect the power cord into the back of the cable modem and plug it into a power strip with power surge protection. The modem should power on by itself once it is plugged in. It will cycle through a power on self test and then make the connection to your cable Internet provider. Once the lights indicating power and cable are green, you are ready for Step 5. It could take several minutes for the modem to connect to your service provider.
  • 5 Turn on the computer and test out your Internet connection. Should your computer still have a problem connecting to the web you may need to reset your cable modem. You will find a small recessed button the size of the head of a ballpoint pen either on the back or front of the modem. This button will be marked "Reset." Pushing it once will allow the modem to reboot and reset all its connections. Turn off the computer before resetting the modem to allow the computer to flush all the networking connections out of its memory as well.
  • If the power goes out and your connection is not restored when it comes back on, always reboot the devices in this order: cable modem first, computer second. Keep the cable modem where it can get proper ventilation. Call your cable Internet provider if you get frequent interruptions to your cable Internet service and rebooting the modem does not solve the problem.
    Jan 21, 2011 | E-Machines eMachines Desktop PC
    How do I hook my wireless usb netopia chip in order to sign on the internet
    You ned to contact an Internet Service Provider to determine if your USB wireless adapter is compatible with their service.
    Read this info for an idea on how to connect to the Internet :-
    There several ways to connect to the Internet.
    1. You can use a cable or DSL modem and connect this modem to the laptop with a LAN cable.
    2. You can use a wireless router with a cable or DSL modem and connect to the wireless router using a wireless card (a PCMCIA wireless card or the laptop may have a built-in wireless card). This wireless card can also be used in WiFi locations such as the airport, McDonalds and Starbucks etc.
    3. You can use an USB G3 wireless adapter. This type of device uses the G3 mobile network and may not give you Internet coverage in some locations.
    All these require an Internet Service Provider and the costs vary widely depending upon the various plans they offer. Check the ISP in your area and compare the plans and cost of their plans and pick the one that best suits your needs.
    Sep 11, 2009 | Computers & Internet
    Can i connect my xbox to my laptop /w pc usb
    Xbox Network Connection using Hub
    This is the most common network configuration and is also the easiest to setup.
    Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
    Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
    Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
    **NOTE** A switch may be used in place of a hub with the same basic setup.**
    That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
    Xbox Network Connection using Router
    This is another common network configuration.
    Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
    Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
    Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
    **NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
    That's it! Your Xbox is now on the same network as your PC
    Xbox Network Connection using Crossover Cable
    This is the last network configuration. For this setup you need at least one NIC card.
    Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
    Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
    **NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
    That's it! Your Xbox is now on the same network as your PC.
    Aug 14, 2009 | Video Game Consoles & Games
    How to connect acer as5920 to internet
    You can connect to the Internet using a cable or DSL modem and connect it to your computer using a network cable or a USB cable.
    Basically you need to see what the Internet Service Providers offer in your location. Beware of the costs of the various plans they offer in broadband speed, their download limits and the penality for exceeding the limits etc.
    Then read the following info to decide what type of Internet access you require.
    If you want to connect to the Internet using a wireless connection then read this.
    What you need first is to install the wireless driver for your wireless card in your computer. If you don't have one you need to purchase a wireless card.
    Wireless connections to the Internet can be achieved by several methods and it depends upon the method of delivery by the Internet Service Provider in your location.
    The most common is by DSL and cable, the modems that are used with DSL and cable connection can have a built-in wireless router. Your computer will require a wireless card to connect to the modem/wireless router and the range is restricted to approx. 100 ft depending where the wireless router is located within the building.
    The laptop's wireless card can be a built-in device or a plug-in device eg a PCMCIA card or a USB device. and these can also connect to a wifi hot spot in locations such as McDonalds. Star Bucks etc.
    There is another method that can connect into the Internet that uses a USB wireless device that connects to a G3 network, bacically a type of mobile transmission and the device is locked into a specific Internet Service Provider. This method gives a wider mobile range (even across states) of connecting to the Internet but usually at a higher cost.
    When you decide which method you choose, you need to consider setting up your wireless network securely to prevent unauthorized access.
    May 12, 2009 | Acer Aspire 5920 AS5920 Notebook
    Computers & Internet Logo
    419 people viewed this question
    Top Farallon Computers & Internet Experts
    Coss
    gaucherre
    Paul Bade
    Are you a Farallon Computer and Internet Expert? Answer questions, earn points and help others
