Question about Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow
Suction is not working as well as it use to
It's driving me nuts! I'm not sure what's stuck up there or got loose but the suction seems fine for the first 3 seconds and then it sounds like suddenly something flaps up and blocks the airway and reduces the airflow down 60% less than what it should be. Please help! I tried to the troubleshooting that they have for their products but i'm not sure what i'm doing. Pleas help thanks! Julia
  • 3 more comments
  • Anonymous Nov 19, 2008
    i bought this one about a month and a half ago. worked great at the begining now it doesnt work. the brush for the carpet doesn't even move.....
  • nevanume Jan 10, 2009
    I have the same thing happening. After a few seconds, I hear a sound like a sudden "twomp" and from then on there is an almost complete loss of suction. Can't find a clog anywhere. Canister seems to be sitting a little low and there is a definite air sound arorund the intake and outtake seals near the gold filter case. I did wash the filter so it should be okay. Gave it plenty of time to dry in the sun.
  • lauramlyons Jan 14, 2009
    I think I must have used it to **** up a packing peanut, but now the suction is very reduced. Help!
  • Norma Shaw Jan 17, 2009
    My dyson starts out fine then I hear a thwomp, suction goes way down and bottom comes up off the floor. I can't find any clogs. Seems like the problem is where the hepa filter is. Is there a way I can get that filter off to check and see what is going on?
  • rlfranklin Feb 10, 2009
    I have no suction for vacuuming bare floors and minimal suction from the wand?
I took the bottom rollers off and reached up in the hole and there was a lot of stuff clogging it. It took some time but I finally got it all out. I think the reason for the clog was because I had accidentally sucked up some water.
I hope this helps
Posted on Jan 24, 2009
Check the pipe or tube coming off the bottom of the unit and also try cleaning the filter in the canister.
Posted on Oct 03, 2008
My QL60 just stopped sucking. The motor and fan run fine.
If the fan is running there has to be suction. If there is none it is because the air in entering via some other port and bypassing the normal intake. Check it out. Check hoses and fittings.
Mar 05, 2016 | Vacuums
Decreased suction for filterqueen vacuum
Put a broomstick or such down the hose, something may be stuck. Look inside with the bag out, is there a screen before the motor?
Dec 01, 2013 | Filter Queen Majestic Canister Vacuum
The floor head is no longer working. The canister works, there is suction, but the floor head is dead. No lights, suction control switch inoperable, no headlight, nothing. It just stopped one day during...
Hi poohbear4760...
Check your wiring going to the vacuum head, some vacuums have a problem with corrosion on the plugs...take your connections loose and lightly sand with fine grit sandpaper the metal ends.
Plug the wires back together and see if it works...if not then it may be that you have a faulty motor in the drive head.
Please take time to rate me
Sep 04, 2011 | Vacuums
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
It's brand new - just out of the box! Noticed the dirty water tank is bone dry. There is no suction! The front removable nozzle seems to be loosely attached.. The metal clip doesn't seem to hold it...
It sounds as if it wasn't assembled correctly. Was it already put together when you purchased it? It sounds like the Brush Bar Belt never got put on.
Let me know if you need more help.
Jim
Oct 10, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
My Dyson Animal has good suction and works fine for actually picking up dirt, but when I use the vacuum with the roller, I hear a grinding/rumbling noise. Its only when I use the vacuum with the brush...
Trace the path of the suction into the tank and see if there is anything loose or ingested. Also, remove the brush and clean as best you can. Perhaps there is something caught in it. Lubricate where it makes sense with some WD40.
Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
When I switch it on the plastic compartment which holds the bag starts to be sucked in towards the bag and there is no suction at the end of the hose
Your Hoover U5076 has a clog. Fist unplug the vacuum from the wall socket. Remove the attachement hose from the door on the head, close the door. Remove the screw just below the main bag compartment, with a phillips or flat head screw driver. Be sure not to loose the nut in back. Hold the base down with your foot and pull up on the handle to sperate the two pieces. The lower portion revieled is the exhaust for the dirt from the motor and that is where your clog should be. Use a flat head screw drive to remove what is there so you have a clean path. If there is no clog there check the up portion that you pulled off for a clog, you may need a coat hanger to dislodge the clog. Once the path way is clear you can reassemble the vacuum and it will work fine.
Apr 20, 2010 | Hoover Turbopower Dual U5076 Vacuum
It wont pick up with a new bag in and it seems to **** back in
Check if there is something stuck in the the suction tube, telescopic wand or in any of the parts involved. I had the same problem due to a number of chocolate wrappers stuck in the wand. I almost went and bought another one, luckily i had the sense to ask the salesman at sears the same question and he put me on the right path. The suction tube and wand are detachable from the unit, so you should be able to unplug the parts and check. This is the same solution if you motor is running fine but you have lost suction and\or bag shows full when it is not. Hope i am saving someone some money by stating the obvious here, just the way the sears salesman helped me.
Nov 07, 2009 | Kenmore Magic Blue 24195 Bagged Canister...
Filters all seem clean and clear, suction is fine,but loud noise
Sounds to me it could be tha fan impellor.
This is vac's etc... email us if you need to.
vacs.etc@live.com
Nov 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow Logo
426 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
