Question about Aspire Acer 7520-5324 Laptop
My screen remain dark when my laptop is turned on.
When I turn on my laptop it comes up, but my screen remain dark and I can not see anything on the screen.
  • Rachelle Aviles
    Rachelle Aviles May 11, 2010
    You might have a backlight issue. Try adjusting the brightness which is done by pressing Fn+up arrow on some laptops. If it doesn't work, try turning the computer on without the battery or the ac adapter or with both. If the screen does not change, you may have to replace your LCD. What's your computer?
    Pls dont forget to rate.., Thanks! ;)
    Scholar:
  • 150 Answers
If you can hear the sound of Windows starting up, your blacklight probably died. If you can't hear the Windows start up sound, Windows may need to be re-installed. Most likely though, it's a faulty backlight.
Please rate, Thanks!
Posted on Feb 27, 2009
Power up computer...hear the windows jingle but the screen is grey
Try connecting an external monitor and see if that gives you video - if that works, your laptop screen may have gone bad and need replacing. If it does not work, check that you are not running in too dark a screen or the wrong mode. I dont know specifically which HP key code changes this but there should be pictures on your "F" keys to indicate this. Remember to push down the"Fn" key at the same time.
Jul 29, 2014 | HEWLETT-PACKARD Computers & Internet
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
Hp 6735sscreen does not come on
Step 1:
An inverter is an electrical device on the bottom of your laptop screen. The job of the inverter is to convert DC electrical current to AC voltage to maintain power to the backlight lamp. If the display on your laptop is dark but working, odds are the inverter or the lamp are at fault. When troubleshooting monitor problems on a laptop, you may need to evaluate the inverter to determine which of the two parts is malfunctioning.
Remove the screen bezel on your laptop. The bezel is the piece of the computer casing that surrounds and protects the LCD screen. To remove the bezel, remove the screws around the screen. Bezel removal method may vary by model. Once the screws come out, the bezel should pop off. The inverter will be under the screen. Attach the positive probe (+) of a multimeter to the pin 1 on the inverter. The inverter has two connections, one on each end. With the laptop screen facing you, look at the left side of the inverter. Pin 1 is the top metal flange pointing to the right. Secure the negative probe (-) of the multimeter to any bare screw. There should be a screw securing the inverter to the laptop that will be perfect for the negative ground connection. Turn the laptop on to test the inverter. Turn the multimeter on and check the multimeter reading. If the display records voltage going to the inverter, such as 19 V DC, the inverter power supply is working. Turn the laptop off. Unplug the LCD inverter connection on the right side of the inverter. This disconnects the backlight from the inverter. Plug a working backlight to the connection on the right side of the inverter. Turn on the laptop. If the screen lights up, the backlight lamp is bad but the inverter works. If the screen remains dark, the inverter is bad
Feb 24, 2013 | HP Compaq 6735s Notebook
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
My power save came on, which turned my laoptop screen off, i moved the mouse, the system started up again but the screen remains black/very dark . the only way i can see my computer screen is if i connect...
It sounds like a driver recovery issue, you may have to do a hard reboot. Hold the power button in for atleast 10 seconds or until your laptop shuts down completely, wait 30 seconds then turn it back on. If this fixes the problem you need to upgrade your video driver and/or your Operating System.
Mar 24, 2010 | Computers & Internet
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Gateway mt6728 doesn't switch on and the red led
Sounds like it needs a new power source or motherboard. Since it is immediately turning off after the red lights then it's probably a hardware problem since there is no time for the software to do anything.
Dec 26, 2009 | Gateway MT6728 Notebook
Aspire Acer 7520-5324 Laptop Logo
272 people viewed this question
Top Aspire Computers & Internet Experts
Jax Planet
Jax Planet
john smith
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
