Question about Compaq Presario R3000 Notebook
Compaq presario R3000
My Start button won't turn it on the first time... It takes me pushing it on about 4 times before the screen lights up. I hope this is a small problem i can fix, before it turns into something bigger.
    Genius:
  • 1,605 Answers
First of all it is a laptop or a desktop computer/
if it is a laptop, the answer is no. it is a surface mounted on/off sw. consumer do't have the equipment to rework that.
if it is a desktop. go to radio shack and get a on/off sw and replace it
hop that helps
Posted on Oct 03, 2008
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Wireless internet not working
My name is ArmyMason, might I suggest that you do a system restore to take your computer back to a date the computer was working correctly. Click on start, all programs, Accessories, system tools and click on System Restore. Tell it to restore and choose a date on the calendar. If this doesn't resolve the issue run Anti virus to see if your computer is infected. If this doesnt help please consider using our Premium service.
Thanks,
ArmyMason
Feb 24, 2009 | Compaq Presario R3000 Notebook
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Video
It's probably the inverter for the LCD, it's located at the base of the display you need to open the top panel and check the connections to the inverter board. Please be careful not to get zaped there is several hundred volts at the output ! , unplug the laptop, remove the battery, remove the 4 screws around the display and carefuly pry the front bezel off. you'll see the inverter board at the base of the display , remove the connectors one at a time and reconnect them. This may help to brighten the display. Also try pressing the Fn key and the F8 key to adjust the brightness, if this dosn't help you'll need to get a new inverter ( around 20.00 bucks on ebay) and replace it.
Nov 21, 2008 | Compaq Presario R3000 Notebook
Where is wireless connection switch on Compaq Presario R3000?
Well if u have the same exact one as myself.
The wireless button is on the front right near the corner. above it and on the corner is the wireless symbol. If its working it should be lit blue. push it and see if it lights up blue for a few seconds. You should get a wireless connection confirmation on the screen.
hope this helps you
Nov 10, 2008 | Compaq Presario R3000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Compaq presario wireless button no longer working
There is a mechanical problem with the R3000 wireless button and volume-down button where they seem to push fine but are in fact failing to make electrical contact. I know of two work-arounds.
* Try pushing the button with a capped pen, gently at first, and then with increasing pressure. (Not so hard you break the plastic, please!) I suspect this gives the buttons just enough extra "oomph" that contact is established.
OR
* Push up on the battery compartment while pressing the buttons. If the battery is in, you can acheive this same effect by putting your laptop on a table and popping up the screen, then applying downwards pressure on that corner of the laptop body while pushing the button. I suspect this aligns things properly so that the button is able to depress just a hair further.
You may even find that these actions "loosen things up" enough to cause the buttons to work like new for a little while. I hope this works for anyone reading this!
Oct 03, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 (intel) 2800 Reset 4 or 5 time a day
Kees,
It sounds like you have fried motherboard. If that's the case, you have to get it serviced by a place your manufacturer recommends. Sometimes the cost can be greater than just buying a new laptop, so shop around and see what you can find price-wise.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Compaq Presario R3000 Notebook
Laptop wont power up.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Good Luck, Read and folow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
