Toshiba 34HF85 TV.....The color is messed up. It has a consistant blue hue that you cannot adjust out without losing the other colors. Happened all of a sudden. Is it a cheap fix or do we need a new flux capacitor?
  • 85 Answers
Could need a new blue output transitor check blue drive circuit or worse case needs crt
Posted on Oct 12, 2008
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Our television is blurry and the screen looks green and pink hue. the writing is crooked as well.
The tv need a tuneup.witch consists of cleaning the projection mirror and color guns and adjusting the convergence.
Jan 25, 2010 | Toshiba 55H70 55" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Toshiba 51h84 color image loses red hue intermitently
You may have a color wheel going bad. Call a good TV Tech for this repair.
Aug 02, 2009 | Toshiba 51H84 51" Rear Projection...
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
Jan 02, 2009 | Toshiba 36AF41 36" TV
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
NO Blue Colors on any station/program
If you are using component video cablesm make sure the blue is connected from tv to source.
Oct 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
My picture has a green and blue hue to it.
After spending a day trying to fix the TV, I found out the problem was actually with my cable box. I have an HD DVR recorder. We unplugged the cable box and plugged the TV directly into the cable in the wall and it worked. So we took the cable box back to our cable company and got a new cable box. (Can't live without the DVR!!)
Apr 28, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
